Question about Samsung Digimax A55W Digital Camera
No power i have just bought this camera used and i have no response from it nothing is happeening is there a reset or something please help
0 characters
1 Points
Camera turns on and says please turn camera off then on again, this is a never ending cycle have tried new battery etc etc, nothing works, also tried the tapping on carpet/table does nothing. please help...
The camera only says please turn off and then turn on again, when something serious is wrong. Could be a mechanical problem. like a lens that got stuck, but also when the camera can't access the memory. Please don't hurt your camera. Only when you know why and how to tap, it could help. But just tapping won't solve anything.
If the lens is really stuck, and you don't know what caused this, probably you can't solve this. When inside something broke, you can't solve this. Did you try to remove the battery for a little while and replacing it. Sometimes it can reset and forget a sensor is telling something is wrong. But really, if nothing helps, you only can get advice in a repair shop or with Panasonic.
Jan 04, 2014 | Panasonic Lumix DMC-LZ20
My Canon SX120 IS digital camera won't turn on. I used it in the morning, set it down on a table, cam back and it wouldn't work. There is no damage. When I press the power button it does NOTHING. Is there...
If you're after a reset button there might be a little hole you can insert a pin into to reset it, look around the camera.
You should also try holding down the power button for a few seconds, it might have a function where doing that does a restart or something similar. Taking the memory card out and turning it on without it is also worth trying.
Mar 05, 2011 | Canon Digital Cameras
I have changed the batteries and pressed the reset button nut nothing please help
Make sure the batteries are good and having the Ah required. Now if there is no response from a reset it is for sure that the camera processor is not responding to any command and is possibily dead.
You will have to remove- the tough job- to get access and see if there are smaller issues like a line break... attempt only with proper tools.
Sep 23, 2010 | Vtech Kidizoom Digital Camera
I have had my camera for over a year now without a problem. It is a Sony Cybershot 7.2 Megapixels. Everytime I turn it on a black screen and the message - "For Use with Compatible Battery Only"...
There is a sentence which i cannot figure out the your wrote in your initial description of your poblem. I think it is meant to be the error message you are getting here is what i read as part of
""For Use with Compatible Battery Only&quot"
Can you try and post it again. From your response i still have te suspicion it could be the batteries, but your error message will help.
Jul 16, 2008 | Digital Cameras
New camera that doesn't respond...
I am assuming you are talking about a Polaroid 8MP I830 camera.
Link for manual
Factory reset
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information
Phone: 1-877-388-3779
Email: Click Here
Customer Support Hours:
(Mon - Fri:) 10:00am - 7:00pm EST
(Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
Mar 28, 2008 | Digital Cameras
Nothing works
Remove batteries and clean contacts both inside the battery chamber and on the chamber lid/cover.( use something slightly abrasive ). If this doesnt help replace fire fuse situated on the main pc board ( underneeth rear cover ).
Aug 27, 2007 | Kodak EasyShare C643 Digital Camera
Response time not where it used to be
"I wonder if it's the battery" (he says desperately bashing his head against a brick wall)
Jun 28, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Digital Cameras Logo
15 people viewed this question
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
