Question about Regina ElectrikBroom RG100 Vacuum
I have acquired an old Regina Electrik Broom
I have no product manual, I cannot figure out how it opens to empty it.
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Posted on Feb 22, 2009
  • pegrs Jan 10, 2011
    Mine is an old model too. But it's smokey black colored, no white cup or latch. I empty it by pushing the side dirt canister down hard while pulling at the top. If you look you can see a little tab to clear at the top. Not a great design but otherwise it's a nice little vac.
    I just took mine completely apart to clean it. I had to leave it and when returned I couldn't remember what went where. Now the brush won't turn. Seemed pretty simple. Without a parts diagram I don't know if I lost a part? Does the belt run directly on the little groved rod coming out from the motor or was there a piece that went on that rod, then the belt? I can see the rod turning when I test with back plate off.
Latch on my dirt devil total pet canister to empty is stuck. how do I make it open
I bet I have the same problem as you. My vacuums canister was put back together backwards and now will not move far enough to click unlocked. I am not sure how to fix this and I cant find anyone on any forums who do :( If you figure it out post it! So far ime just trying to muscle it open.
Mar 26, 2012 | Dirt Devil Breeze Bagless VacuumVacuum
How do u open up the compartment to empty the trash
I couldn't figure that out either...since I misplaced the owner's manual...Anyway, there is a little gray colored knob at the top of the "collection" canister...and simply press that button and it disassembles that canister from the rest of the upright and then you are able to empty that trash contained therein.
Sep 29, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Same problem removing the easy empty cup..
The dark gray plastic slide is separate from the Easy Empty Cup. Just slide the release tab all the way to open position, and then pull the Easy Empty Cup straight up. With a little effort, the cup will dislodge from the dark gray plastic platter.
Sep 08, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Kenmore Quick Clean - how to remove dirt from cannister
this is the web site for Kenmore owners manuals
--->http://www.managemyhome.com/mmh/<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Kenmore Quick Clean 30012 Vacuum
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
Jan 20, 2009 | Sanyo Transmax SC-180 Handheld Vacuum
HOW TO EMPTY
One of 2 ways, some you just take the top off, it will have a paper bag that you can toss and put in a clean and empty one. The other is the bottom is actually a bucket that unhooks so you can empty it. Hope this helps.
Nov 05, 2007 | Cana-Vac 511Q Central System Vacuum
Vacuums Logo
798 people viewed this question
Top Regina Vacuums Experts
JoeVacs
Are you a Regina Vacuum Expert? Answer questions, earn points and help others
