HP Inkjet C3100 - Boot up problems
HP Inket C3100. When the printer's USB plug is plugged in, it does not allow the computer to boot up. Only after unplugging the printer's USB cable, does the computer boot up and only then can we replug the USB cable and it prints fine.
Is there a way keep the cable plugged in and have the computer working properly?
Please help.
  • 903 Answers
Try going into the bios by pressing F2 as the computer boots, then go to boot options and choose to boot from the hard drive first, cdrom second and floppy drive third (if you have one) then save the changes and exit the bios. You computer should boot as normal now.
I hope this helps
Posted on Jan 07, 2009
How do i install PRINTER
Setup the printer where you are going to use it & then make sure you have a USB lead ready and plugged into the printer but do not plug into PC yet, assuming you have the software & drivers cd that came with the printer ( if not then download software from HP website ) then install cd first then when it asks you to plug in the USB Cable & power on the printer follow on screen instructions until completed.
Mar 01, 2015 | HP Photosmart C3100 series
I have a hp printer/scanner 3510 and hp computer, the printer works fine but it won't scan!! the lcd screen says, "the computer is not responding. check if the usb cable is attached" the cable is...
Unplug the USB cable to the printer. Uninstall the HP printer software. Reboot. Reinstall the HP printer software and WAIT until the installation program tells you to plug in the USB cable.
Mar 09, 2014 | HP Photosmart C4280 Aio Printer
When I plug the USB cable into printer, computer does not see the printer. I have tried two different cables and ports. HP Tech support told me that there is something wrong with the USB connection port on...
refresh the USB ports:
1. Right click MY COMPUTER
3. Select HARDWARE
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Nov 11, 2010 | HP Photosmart D5069 InkJet Printer
My HP PSC 2410 is not found when plugged in to my pc
try to unplug printer restart your computer, remove drivers and plug in computer found new hardware must be reflected if not replace printer cable if using usb cable try to check if usb enabled in bios setup.
Apr 10, 2010 | Office Equipment & Supplies
Computer won't boot with the Lexmark X4650 printer attached with USB
Change boot order in BIOS menu to get rid of all USB devices. Plug it into a different port. Set USB in boot menu to USB 1 not USB 2
Oct 29, 2009 | Lexmark X4650 InkJet Printer
The computer stops loading and waits for approximately 2 minutes before continuing to boot. When we removed the hp Printer usb Plug and the computer boots fine. Please help. Thank you, Althea Mason
The symptom you described happens because your printer is capable of reading memory cards.
When you turn on your pc with the USB cable connected, your pc is checking the memory card slots in your printer to see if any of them contain a valid operating system that can be used to boot the pc.
Once your pc determines the memory slots do not contain a bootable operating system, it then continues the boot process and loads the operating system from your hard drive.
When you disconnect the USB cable, the memory card slot are not present and the pc boots normally. I've run into this exact same situation at work with certain models of HP printers.
My best recommendation is to check the BIOS in your pc to see if it is possible to disable the option that allows your pc to boot from USB devices.
When you first turn on your pc, the screen will display a message informing you of which key to press to enter the setup program. This is where you want to check to see if the USB boot option can be turned off.
Note: Not all pc manufacturers provide an option to disable booting from USB devices.
If you can't disable the USB boot option, check to boot order to make sure the internal hard drive is listed before any USB devices.
I have to say though, setting the boot order so the internal hard drive appears before any USB devices does not always solve the problem even though it should.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Hp laserjet p2015dn
Turn off the printer and unplug the USB cable. Open up Device Manager. In the View menu, make sure that Show hidden devices is checked. Click on the + sign next to Printers in the right-hand pane. Uninstall any entries for Laserjet P2015. Reinstall the drivers for the printer. When instructed, plug in the USB cable and turn on the printer. It should recognize the device and allow you to print a test page.
Mar 31, 2009 | HP LaserJet P2015dn Printer
HP 8250 Prints wierd stuff on computer boot up
Used HP's chat, they helped walk me through it. NO CHARGE! You push the 'on' button for 45 seconds after you disconnect all the cables. Plug in the power cable only. Then print a test page. If that works, plug in the USB. Should fix the problem. I'd recommend working with HP, as they can check the internals on your machine while you chat with them.
Feb 05, 2009 | HP - HP Photosmart 8250 printer
How do I add HP Photosmart C3100 all in one to my computer
Unplug printer from pc and wall.
Delete the printer from device manager.
D/L driver HERE (select O/S)
Shut down PC
plug in printer to PC an wall
ReStart PC
Let windows recognize the new hardware.
Point it to the file you just D/L when it asks for driver.
Jan 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
Lost communication of hp printer to our pc
It is a power problem Check all cables to ensure they are plugged and snug. Also, you may turn off both computer and printer. Unplug all cables to inlude USB cable to PC. Boot up PC to ensure all ports are in power and then turn on printer.
Please rate this solution.
Jan 08, 2009 | Lexmark X6170 All-In-One InkJet Printer
101 people viewed this question
