Question about Olympus VN-960 Digital Voice Recorder
Will not turn on
I put in new batteries, set up the clock and date, then it goes dead. I remove the batteries, put in different ones, go through the setup and it goes dead again and I can;t turn it on.
  • louinjax132 Jan 08, 2009
    That did the trick. Thanks
    President:
  • 919 Answers
Make sure that the device is not in the Hold position. This might be why it keeps shutting itself off. Hold is basically like the on/off button.
Posted on Jan 07, 2009
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Wall scoreboard clock model #0028 not working after outlet blew
Remove several screws around perimeter of clock. Open up clock and find small (quarter -sized) battery. Remove this battery - it may be hot glued in place but you need to remove this. You don't have to replace it just remove it. Apparently this battery is used when you have a power outage to retain date / time, but when it goes dead it won't allow the clock to operate. So just remove it and put the clock back together and all should be fine except you will have to reset the date etcetera when you have a power outage.
Jun 09, 2013 | Computers & Internet
Everytime I turn on my camera it asks me to set date/time. It goes to the default date/time setting of 00.00.0000 00:00 mm/dd/yy. What do I do to set the date/time so that it permanent? The photos are...
It takes around four hours for a freshly charged main battery to charge the internal backup battery. It you do that and it still doesn't charge it, you need a new internal battery. The fully charged internal battery in most of them will hold the charge for up to 3 weeks with the main battery out of the camera.
Oct 19, 2011 | Canon G12 Digital Camera
My computer time and date keeps resetting itself to a different time. I'm connected to the internet but that is all. Why does it do this?
the clock microchip inside you motherboard is run by a small lithium battery model # CR2032 ( the size of a small coin) this is embeded in the motherboard, this can be replaced with a new one by removing the PC's cover and looking for it on the motherboard .....once replaced the clock can be re-set to the current time....once the machine displays the Desktop screen....
Oct 06, 2010 | Computers & Internet
Clock in computer will not maintain time and date
Yes it very probably is the CMOS battery, time is kept counting electric pulses, when the computer is turned on there is power and memory to do this, but when it is turned off it relays on the battery to keep this an some other settings, maybe you're receiving a warning at boot time. Check this guide for replacing such batteries:
http://www.computerhope.com/issues/ch000239.htm
May 13, 2010 | HP Pavilion a350n PC Desktop
3V laptop Battery
It keeps your bios alive while your comp is turned off your bios is what tells your pc how to start
Mar 26, 2009 | HP Compaq Presario C502US Notebook
Won't boot normally and clock goes back to 2007 when turned off
Your laptops BIOS battery is dead. I THINK on this model it is under the laptop battery, looks like a little watch battery. Get a new one and replace it. This is what lets the BIOS store it's settings.
Feb 15, 2009 | Toshiba Satellite L45-S7423 Notebook
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
I have a e system desktop the clock keeps running late
Computers have an internal battery on the motherboard that helpd the board retain certain data when the computer is off. If the battery is low or dead it will cause this problem. The easiest way to replace the battery is to open the side of the computer when it is off and remove the battery from the battery holder on the motherboard. The battery looks just like a watch battery. Replace it with the same kind of battery (available at most drug stores) once you have replaced it turn on your computer and reset your clock.
Dec 29, 2008 | E-Machines eMachines Desktop PC
I have to set the date/time every time I turn on my Canon A720. Once I've set the date/time, it stays set until I turn the camera off.
YOUR PROBLEM SHOULD BE OVER! ON THE BOTTOM OF YOUR CAMERA IN THE COMPARTMENT WHERE THE TWO BATTERIES GO IS A SMALL DOOR. THIS IS THE CLOCK BATTERY DOOR! YOUR CLOCK BATTERY MUST BE DEAD OR MOSTLY DEAD. AT LEAST IT IS WORTH CHECKING OUT. THIS IS THE MOST LIKELY CAUSE OF TIME DATE FAILURE BECAUSE IT WILL RUN WITH THE MAIN BATTERY POWER WHEN THE CAMERA IS ON, BUT WHEN YOU TURN IT OFF, THIS SMALL BATTERY IS SUPPOSED TO KEEP THE TIME, DATE CURRENT IN THE OFF MODE AND IT IS DOING IT! CHECK IT OUT AND SEE IF THIS DOESN'T SOLVE YOUR PROBLEM. GOOD LUCK! HOPE THIS WORKS FOR YOU!!
ARCLIGHT1217
Nov 08, 2008 | Canon Cameras
Olympus VN-960 Digital Voice Recorder Logo
55 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
