Question about E-Machines T3624 PC Desktop
My keyboard is not working. I went to control panel/keyboard and it says it is recognized. the lights are on, but the keys are not working. Can you help?
  • mandsfaulk Jan 07, 2009
    Ps/2
  • Dan rogers
    Dan rogers May 11, 2010
    is the keyboard usb or Ps/2? What king of os are you running what kind of machine is this on? Who is the manufacturer of your keyboard? When did it stop working?
    Problem Solver:
  • 11 Answers
Plug in a different keyboard to see what happens
Posted on Jan 07, 2009
X809745 001
test the keyboard for regional , languages in control panel, and set up the keyboard languages.and try again.
However you can restore the computer use the "system restore" to the laste date that you know was working good. and fix it
You can enable the Hot KEYS, in BIOS setup .
God bless you
Jul 29, 2013 | Computers & Internet
How can i unlock my keyboard
Recognize that you have a locked keyboard.
If your PC computer is not responding to keystrokes or is responding very slowly, you could have a locked keyboard.
Use your mouse to move the pointer over the "Start" button.
Use the left-click button to bring up the "Start" pop-up menu.
Position the pointer over "Settings" and use the left-click button to select. T
hen select "Control Panel." On some versions of PC operating systems, you can select "Control Panel" directly from the "Start" menu.
Select "Accessibility Options" to bring up another menu, then select "Keyboard."
You'll see three options that have check boxes.
Make sure each check box does not have a check mark in it.
The three options are "StickeyKeys," "FilterKeys" and "ToggleKeys."
Note that these options can become checked if the keyboard operator has repeatedly depressed the "Shift" key in rapid succession--or if the "Shift" key is held down for longer than eight seconds.
If the keyboard is still not responding, the problem could be that the computer has lost communication with the keyboard.
Turn off the computer.
Disconnect the power supply.
Remove and then reconnect the keyboard cable, then reconnect the power supply.
Turn the computer on.
This will reboot the computer, allowing it to recognize the keyboard.
hope this helps
Oct 03, 2012 | eMachines Computers & Internet
I have a nexxtech keyboard not recognizing keys strokes. The "office lock" light is lit. If I press that light it goes off. No other keys respond to touch.
the light on only means its getting power try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! orared X right click update driver
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer - No need to waste hours upon hours every week searching the Internet for the latest driver files. You have better things to do than a driver scavenger hunt!
hope this helps you
Oct 29, 2011 | Lenovo Keyboard
Keyboard not working
I presume it is a PS/2 keyboard one that plugs into the Green Connector at rear of PC, if so, then these ports often fault, with the mouse being OK. The best way around this is to get a cheap USB keyboard, and install it. Ensure you set the USB ON in BIOS too. You could try uninstall/reinstall of KB from device manager first.
Feb 08, 2010 | E-Machines eMachines Desktop PC
Dell laptop keyboard and a not working
Your have a problem with your alt key you have replace the keyboard because one of your may be alt key is pressed from inside
Jun 26, 2009 | Gateway 2520915 Keyboard
Acer Aspire 6920: Broken Keyboard & Mouse Pad
open your laptop keys with nail cutter and see any problem is there
Apr 25, 2009 | Acer Aspire 1640Z Notebook
Asus M2N keyboard problem
You don't need a driver for a PS/2 keyboard nor a USB keyboard. The keyboard lights should lite up at post. After boot press the Caps Lock key and it will light the corresponding light on the keyboard if the controller works. If not it is the motherboard. If you are strapped for bucks get a mobo that can use the same cpu, RAM and drives. Good luck, Steve Medley
Nov 06, 2008 | Computers & Internet
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Keyboard
Did you install the CD software program that came with the Keyboard? It will recognize the keyboard but will not give you all the key functions.
After installing the CD software try this if it still doesn't work.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Oct 13, 2007 | Dell R6053 Keyboard/Multimedia Control...
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
E-Machines T3624 PC Desktop Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
