Question about Magellan Roadmate 760 GPS Receiver
Aquiring a GPS signal
I have a Magellan Roadmate 760 and when i first bought it it worked just fine. Now it seems like when i turn the unit on it takes a long time for it to aquires a GPS fix. This happens every time i turn the unit on. It can be a sunny day driving down the highway and it will take 20-25 minutes to aquire a signal. After it aquires a fix it's ok until i turn the unit off. When i first bought it the unit was very quick in aquiring a signal. My Dad has a Magellan Roadmate 800 and he says he is having the same problem. Any suggestions would be appreciated.
  • sephus Jan 02, 2008
    I have a garmin 340 street pilot and it will not aquire a gps signal it has been saying aquiring a signal for nine hours?
Daniel,
My 760 would not acquire a signal as well. When I opened the unit, I found that RF cable loose on the PC board in front of the HDD. The contact the RF cable snaps into had broken solder joints, which is amazing when you consider that this tiny connector is soldered to the PCB in three seperate locations. Let me add that if you don't have a lighted magnifying glass designed for this type of work, be ready to take it to a technician that does!
Anyway, I just wanted to say thanks for your expert advice and that I learned two valuable lessons over the last six months.....determine where a company's tech support resides befor spending $1000 and save your frustration and do your own research on the web.
Thanks Again,
Greg
Posted on Mar 08, 2008
    New Friend:
  • 24 Answers
If you have any signal problem again please follow the steps given below it works..,
NOTE: If you are trying these steps from your vehicle, it is
Recommended to follow when the vehicle is in a stationary position.
Make sure that the device is exposed to the clear view of sky.
With the antenna pointing upwards, remove the antenna and then re-insert.
Swivel it up and down to make sure its securely placed.
wait for few mins and check the signal indicator.
Still not working,
  • Turn on the unit and select any user.
  • Make sure that the antenna is in the upright position and the unit has
    a direct line of sight with the sky.
  • Select 'Option' from the keypad.
  • Then select 'Configuration'.
  • Scroll down to select 'Diagnostics'.
  • Scroll down again to select 'Initialize GPS'.
  • At this point you would receive two options, 'Yes or No' - select 'YES'.
  • Now scroll down and select 'Set GPS Position'.
  • Enter your City, Street name and number at the corresponding
    prompts.
NOTE: The address that you are entering in the Set GPS Position should be the address at which you are at that point of time.
Posted on Jan 27, 2008
Hi Daniel, Please let me know how to get user menu on Magellan 760, you suggested to rest the GPS data go to user menu press the zoom out key press the zoom out key. Thanks Nadeem
Posted on Aug 12, 2007
  • nadeem67 Aug 14, 2007
    Hi Daniel,
    I opened my unit and found the gray clour RF cable is out from I/O. Now I am not sure really where exactly this will connect on I/O.
    I will really appreciate if you let me know if you have any information.
    Thanks
    Novelist:
    Scholar:
  • 86 Answers
Ggleed, On the 760 unit, I would try: After resetting GPS user data, make sure the problem still exists before proceeding. 1. Resetting GPS user data- At the user menu press the zoom out key (-) and the repeat button at the same time. Once the menu appears select reset GPS user data (that may or may not be verbatim but it's not the Reset user data one). 2. Reset user data Resetting user data will cause you to lose all of your POI's and user information, which of course can be re-entered manually. So, depending on how much info you have on your unit and if the time delay is that much of an issue you can do the same process as before except this time do select reset user data. 3. Check RF cable connections This involves opening the unit up. This is at your own risk. Once the screws are out you will see a either gray or black cable going from the main board to the I/O board (the board screwed into the rear housing) Check both sides of this cable as the side on the I/O board has a history of either coming undone or the soldering on the I/O board connector is loose. Unplug each side of the RF cable to make sure the solder connections are solid. If this is the problem, then you need to either find a soldering iron or find someone who can re-solder it for you. This is not an uncommon find in the 760's. Hope this helps! -Daniel
Posted on Jun 07, 2007
Part number 702142-02 has a loose connection where the power cord plugs in. I need that part and can't seem to find it online.The unit I have is the Magellan Roadmate 760
Have you had any luck with this problem.. I'm having the same issue.. Obviously a product defect... Please let me know, if you have any sollutions.. Futuresportinc@yahoo.com
Thanks in advance...
Aug 02, 2010 | Magellan Roadmate 760 GPS Receiver
No signal in two units, did reset with magellan tech service, still gets stuck in the same location and no signal
Plug it in, turn it on and let it sit out in the open. If the unit is working at all, it will eventually find and lock onto the satellites. The 760 I'm using now came from California and it took over 2 hours to lock on. When I start a trip now, I let it sit before starting to drive and it locks on in just a few minutes.
Oct 27, 2009 | Magellan Roadmate 760 GPS Receiver
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
The weakness of the 760 is the cradle. Is the power wire or the cradle loose or wiggles? You may need to buy a new cradle if that is the case. They are expensive. I soldered my power wire right into the cradle and it worked fine.
Aug 26, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
How do I reset my magellan roadmate 760?
Your magellan roadmate 760 unit does not have any reset option.To over come the signal problem just follow the trobleshooting steps givven below .............
Still not working,
    prompts.
Feb 10, 2008 | Magellan Roadmate 760 GPS Receiver
The cord for the roadmate 760 takes a 3 amp 250 volt fast blow fuse.
Feb 09, 2008 | Magellan Roadmate 760 GPS Receiver
Unit will not acquire the satellite signs
FYI ....My Roadmate 760 would not aquire a signal, I went to diagnostic screen and found it was detecting/tracking 0/0 satellites. Held the plugged in unit out the window and within 10 seconds was tracking 7 satellites! Turned out my 1999 Olds Silhouette Van has a anti-glare filter inside the factory windshield that blocks GPS signals.My wifes 2001 Chevy Impala also has same type filter. Check your windshield, filter is visible inside glass to within about three inches of edges of glass. Worth a look.
Dec 29, 2007 | Magellan Roadmate 760 GPS Receiver
MAgellan Rodmate 760
You should return it and get another one.
Jun 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
198 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
