Question about Belkin N Wireless Modem-Router F5D8633au4A
Losing internet connection
I keep losing connection to internet but have excellent signal on wireless n belkin
  • 1 more comment
  • Anonymous Jan 14, 2009
    I have same probem. About half the time all is well but for the other half the blue internet connection light and the blue wireless light go out and there is no internet connection. I was told it might be interference on the channel but I have changed the channel and it makes no difference.
  • eldarwen2005 May 11, 2010
    How does one go about resetting the rekey time/time till rekey?
  • Anonymous Mar 15, 2014
    why do i keep losing my internet signal
    Scholar:
  • 67 Answers
Set your "rekey time/time till rekey" to a longer interval.
Posted on Jan 18, 2009
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
My belkin n series keeps losing internet connection hard wired to my computer and three wireless computers in the house. when hard wired to the virgin broadband modem everything works fine
I would suggest taking a look at your modem LEDs. What happens exactly when you lose connection? A look at the LEDs should give you some thought as what might be causing this. You can also try resetting your Belkin to default factory settings by pressing the Reset button at the back for 30 seconds, and then putting back your Belkin settings.
Nov 16, 2010 | Belkin N1 Wireless-N Wireless Router
I KEEP LOSING CONNECTION FROM MY BELKIN ROUTER. EVERY SO OFTEN I LOSE AND IT KEEP SAYING "NETWORK DIAGNOSTICS PINGED THE REMOTE BUT DID NOT RECEIVE A RESPONSE.
is that a wireless connection ? Does it happen with the wired connection as well ?
If its wireless, can you chk if you have any static devices close by that are bothering the signal .Also, make sure you have the router as close as you can to the computer If you are having a wired connection, suggest you try with a different cable
Thanks
Ranjit
Oct 30, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
I lose broadband once I diconnect the ethernet cable
you are providing the username and password from your laptop. So its disconnectiong when you shutdown your laptop
Try to use the username and pass from the Modem itself .
Hope you can find difference. Thanks
Dec 12, 2008 | Computers & Internet
Keep losing internet signal
Have you tried updating the firmware of your router? Updating the firmware of the router will fix that issue. Make sure after updating the router's firmware, hard reset the router. To hard reset it, Press the reset button on the back of the router for about 20 seconds, then unplug the power for 30 seconds then plug it back. Reconfigure the wireless settings of the router. Make sure to change the wireless channel of the router to channel 11 or 1 and not 6 to avoid interference.
Sep 16, 2008 | Belkin (F5D9230-4) Wireless Router...
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless router loses light display
I would call Belkin, sounds like a faulty router.
How long have you had it? And what made and model is the router?
Oct 19, 2007 | Belkin (F5D7231-4) Wireless Router
Wireless Internet Connection
Are the wireless router connected to a network?
Oct 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin N Wireless Modem-Router F5D8633au4A Logo
480 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
