Freezers Logo
Anonymous Posted on Sep 01, 2017
My freezer is froze
My Low Temp light came on so I started looking to see if I could find the problem, I cleaned out the freezer and took off the cover for the coils and noticed that they where froze solid, So I unplugged the unit and am waiting for it to defrost. But right off hand I would think that the auto defrost isn't working. But not sure. Do you have anything else I should check.?
J Rosado
Level 3:
  • Master 1,202 Answers
  • Posted on Sep 01, 2017
J Rosado
Master
Level 3:
Answers
1202
Questions
Helped
499892
Points
3432
If there is a fan motor for the frozen coils, make sure the fan works.
Chris Huff
Level 3:
Top Expert:
  • Frigidaire Master 6,289 Answers
Chris Huff
Frigidaire Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017814
Points
74913
There's also a defrost thermostat / bi-metal that will typically go bad. If any one of those 3 defrost components (timer, heater, or thermostat) go bad, unit won't defrost.
richie46
Level 3:
Top Expert:
  • Frigidaire Master 12,962 Answers
richie46
Frigidaire Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941707
Points
58151
The defrost element and/or timer.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Feb 20, 2008
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Anonymous
  • 161 Answers
  • Posted on Jun 30, 2008
SOURCE: UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Anonymous
  • 158 Answers
  • Posted on May 09, 2009
SOURCE: my whirlpool afb 6640 freezer has a red light on
thermostat is defective(loose contact)
Anonymous
  • 340 Answers
  • Posted on Jul 03, 2009
SOURCE: Hello, we have a three year old LG GR-359SQ Fridge
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Anonymous
  • 255 Answers
  • Posted on Sep 08, 2009
SOURCE: defrost coil looked red hot in freezer
yes, it does this, it is in defrost cycle.
Freezer MQU2057: Maytag freezer on bottom froze up (literally frost...
Your tech doesn't have the issue completely fixed. You have a defrost issue and defrosting manually is just the start to resolving your issue. You have to diagnose why it fails to defrost. You have a heater, control thermostat,frost sensor, etc. to check for a failure after defrosting it. Get someone that knows how to complete the job right!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
1helpful
Hi i have 2 freezers turned one of to clean
Hi David,
It may have gone into the defrost cycle while you were cleaning it. Leave it turned on for about an hour, if it still does not start on it's own send me the model number off the tag and I will help you find out what is wrong.
Apr 30, 2010 • Freezers
3helpful
2answers
Freezer not cooling, food is defrosting, model# 28042 sears ask me to clean off the coil where is the cooling coil located
To answere your question : The cooling coil is called the evaporator and is located behind the backwall of the freezer.....But this is not what they want you to clean. They want you to clean the condenser coil, witch is either the big black coils on the back of the unit or they are located under the unit.
you might also make sure you here the fan inside the freezer. open the door and press the door switch and see if you here the fan running. if you don't, then you might have a evaperator fan motor that is bad.
The next thing you shoud check is the back wall of the freezer have frost or did it have frost on it. if it did you have a defrost problem.
This is where you should start. There are many other things that could be rong.
Freezer won't stay set at 0
It is working to hard, look in the rear down low and check to see if you can vacum the fann and coil clean unplug it first. they tend to get real dirty real fast.
My whirlpool afb 6640 freezer has a red light on
May 09, 2009 • Freezers
4helpful
Evaporator unit keeps on building ice. question what is the nornal operating pressure on low side and on the high side for truee freezer using 404 refrigerant
I'll try to give you the "Readers Digest" version.
First, make sure there is no ice build up on the evap. Light frost is O.K. as long as it does not effect air flow. (Very Important). All fans need to be running. Again, an air flow thing. There should be some product in the box but not too close to the evap. Again, an air flow thing.
The expansion device can effect your pressures to some degree i.e. Cap tube vs. TXV.
As a general rule of thumb, which I use almost everyday when it comes to pressures:
Low side is based on the temp difference between evap temp and condition space in the box. In freezers, it is almost always 10 degrees. If the box is 0 degrees then the evap needs to be at a minus 10 degrees. That is a pressure for R-404A of 24.5 psi. This only holds true when the temp in the box is approching set temp. I would say, about +10 degrees. 0 Degrees for the evap for R-404A is 33.5 psi.
High side should be ambient temp +30 degrees and then convert to a pressure for the refrigerant.
Example: 75 degrees in the room, +30 degrees equals 105 degrees. Now 105 degrees converted to a R-404A pressure is 253 psi. This will get you very close to the desired high side pressure.
I would look at low side first to see if it is within reason. Don't let the high side get too high. Increases the compression ratio and overworks the compressor.
Your icing problem could be a defrost issue and not a refrigerant charge issue.
Good Luck and hope this gets you started.
OF light won't turn off to allow freezing
i belive that the temp select you can choose temp, but when the min temp is selected, the next choice is OF, try resesting the control to a warmer/ or colder temp.
1helpful
2answers
Kenmore 16.7 cu upright frost free freezer
Since everything seems to work properly it may just be your temperature sensor, etc. has always been out of calibration. The t-stats are only about $23 bucks and very simple to replace. Pull the temp knob off and there you'll see the screws. I'd start by replacing this first then seeing if the temps are more controllable. Usually a 3-5 setting is good so being way low on the dial seems unusual. The drain hole copper I use is 1/4" copper tubing that I cut to about 6" long, hammer a few inches flat then use pliers to round a hook shape into the flat end. Test hang it on the heating element with the other end of the copper about 1" into the drain hole (cut as needed). That ensures the water will drain and not refreeze before if flows out. Also check that the hole drains fast, use hot tap water and pour a 1/2 cup in real fast to make sure you see it flow out fast. If it's slow the drain tube may be clogged (I've found green peas are perfect to plug a hole). www.partselect.com or www.repairclinic.com are good part sources. Let me know how it goes. http://tinyurl.com/6ealmc for part to swap out.
Oct 15, 2008 • Freezers
1helpful
2answers
Freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Feb 16, 2008 • Freezers
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
