Question about GE DBSR453EBWW Electric Dryer
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
The dryer gets clothes caught between the drum and the plastic part at the top of the dryer. I made sure that the bearing was okay in the back of the unit. What do I need to replac to repair the problem?
Thanks,
John P. Dryer squeaks and pinches clothes
  • roswell350 Jan 07, 2009
    Thanks. Just ordered the parts
  • Anonymous Mar 16, 2014
    I have looked all over and cannot find a snag or something caught inside the dryer but I keep getting holes in my clothes the size of ink pen bottoms.
  • 126 Answers
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Posted on Jan 07, 2009
  • keith mcintyre Nov 21, 2011
    Hi. I too had the exact same problem and I think diane trott has answered your question perfectly. What I did was to place a piece of teflon (in addition to replacing the plastic piece) in the rectangular hole at the top of the plastic bearing. Good luck to you and thanks to Diane Trott for the part number of the front bearing.
The back of dryer drum rubs on the gas diffuser lip
You did get the right replacement bearing assembly; did you also replace the bearing retainer and ground strap to the gas diffuser?
I'm sure you followed the repair procedures as described in this video http://youtu.be/MPXu-Ya8CBY
And if you did double check everything I suggested- then the next thing I would have to ask, is the noise you are hearing only happening when the dryer is full of clothes or does it also occur when the drum is empty?
If the noise occurs only when the dryer has clothes in it, you may be overloading the dryer.
If the dryer is making the noise whether the drum is loaded or unloaded, then the next logical step is to check for level.
Place a carpenter's level on top of the dryer; check it side to side; and front to back; adjust the leveling legs if necessary.
From my experience, a scraping sound could be caused by metal or hard plastic objects getting caught between the cabinet and front seal of the drum. And you already had it apart to replace the front bearing and slides; and I'm sure you inspected the diffuser for any damage or being out of round when you installed the rear bearing...at this point, predicated you did replace the bearing retainer and ground strap- the only 3 things you didn't replace is the gas diffuser, the drum, and diffuser- not to suggest that you do :) Please keep me posted. Best regards.
Mar 11, 2014 | Dryers
Clothes getting caught in Kenmore dryer
The bearings under the drum may have failed, making the drum drop, so the gap is bigger. Replacing drum or bearings is a lot of work, cheaper to replace the dryer. Or you could make a plastic ring yourself that is thicker to fill the gap....
Dec 27, 2013 | Dryers
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Clothes getting stuck
check the top drum slides and tub bearing slide support. it is made of plastic and when it or the slides wear out the drum will drop down enough for clothes to start snagging
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=395857&ModelNum=NWXR483EG3WW&mfgModelNum=&ManufactureID=2&Selected=00125553i02&Position=3&mfg=GE&Type=&Mark=3
May 28, 2010 | Hotpoint Ariston NWXR483EGWW Electric...
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
Clothes getting caught between drum and front of dryer
Hello Friend, This problem is real common in Hotpoint/GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | Hotpoint NVL333EY Electric Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Torn clothes
there should have been a plastic gaurd on the lint catcher inside to keep this from happening, at anytime when taking your clothes out did you find something you might have though how did that get in there> could have been it, or look under the dryer and see if it made it's way out past the drum to the floor
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
359 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
