Question about 2wire Wireless-G 802.11g ADSL Gateway
Wireless router/ modem is no longer wireless
The unit began shutting down and took it to my IP who reconfigured it, now I no longer have wireless. How can I reconfigure at home to get wireless back on?
  • 366 Answers
Follow the tip I prepared to enable your radio feature.
Let me know if you do not find the switch on your pc (refer to your documentation.
Posted on Jan 07, 2009
IP Address Errors
It sounds like you may be having IP address conflicts. Many Xbox users have a fixed IP address set in their unit and then have a Port Forwarding done in the router to provide faster play. If you reset the router all this is lost. Then what can happen is that the router will assign a device the reserved IP address of the Xbox. When you turn the Xbox on, then it cannot connect as there is another device already assigned that address. Reconfiguration is required to prevent IP conflicts.
Dec 08, 2013 | Linksys Wireless-G WRT54GS Router...
My Netgear N600 is constantly dropping the IP address. I have Cox internet and the modem has battery backup. So to reset the network, I have to power down everything, press the reset on the modem and...
Have you tried changing the channel the router is broadcasting on? sometimes if a neighbour is using the same chanel you can get conflicts. Take it of Auto and choose something like 9,11,12
Sep 01, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have a Belkin N1 MIMO wireless modem router with a deactivated security. How do I re-activate the security?
you need to enter on the admistrator of your router to reconfigure it or to activate the security.just connect to router then go to iexplorer and type the ip of your router.the ip of your router is the default gateway of your computer ip.
Jul 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I had to unplug everything yesterday while the electricity was being worked on. Now my internet works fine through the modem, but not throught my Lynksys Wireless G2.4. What do I need to do?
You have to reset it to factory then reconfigure it.
Look at the back, youll see a reset button,disconnect the ethernet cable from the modem to wl router,then press and hold down the button for like 10 seconds. Let go and the disconnect from power,then reconnnect power.
Now use the setup cd that came with it to reconfigure it or use the Linksy Router default IP address.
Jan 27, 2010 | Linksys Wireless-G WRT54G Router
Modem shuts down when I use skype
Jan 09, 2010 | Computers & Internet
My wireless router wont let me connect to the internet, the internet light on the unit is amber. My unit is netgear WGR614
When the router sees an ethernet connection on the WAN, it gives an amber light until it links to the internet. So, either it's a DSL and you need to set the PPPoE properly, or it's a cable connection and you need to configure it with the DHCP or IP address.
Check your ISP's modem instructions carefully and reconfigure.
Nov 20, 2009 | NetGear WGR614 Wireless Router
Can't connect to wireless network, message says aquirinng network address and then goes back to previous page and stays there
reset the router back to its original default settings, by holding the reset button on the unit, while the unit is on......making sure to hold the button in for atleast 20 seconds. then log back into the router and reconfigure it as necessary. it is possible that the router reset with WEP encryption enabled, in which case, you can either disable that under "wireless security" or specify your new passphrase and write down your WEP keys, so you can use your router wirelessly.....also, make sure the router is set to DHCP. if it needs to be set to static, then you're going to have to specify your IP addresses for each connecting computer manually, as well as the IP info for the ISP you have.
also, make sure that each connecting computer is set to automatically acquire IP and DNS adresses. if so, restart the connecting computer, and you might consider resetting your DSL or cable modem if you have one. if this doesnt fix the issue, then there is either something wrong with the IP info you have inside the router, or your computer isnt configured properly for wireless, in which case, just let me know and i will gladly walk you through the process of configuration.
also, you might try to connect to the wired side of the router (with an ethernet cable) and see if you have internet access that way. this will give you a better idea of what exactly the problem is weith the router. if the ethernet cable wont let you access the internet either, its an IP issue, modem issue or the router is just bad.
Sep 24, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Lights wont turn off even if netwrk wires are unplugged..
You'll have to hold your reset button down for atleast 10 seconds, or even more, then you'll have to reconfigure you entire connnection at address
However before doing that, try and power down the whole unit for a minute or so and power it back up, then go to you computer's wireless connection and renew your IP address [that's if you have automatically assigned addresses]. otherwise you might have to check that you router and computer are operating on the same page [ by this I mean, if your router is assigning automatic IP, make sure your computer is not set to use a static IP, In my years of network, this has always been problem I have experienced on some routers]
Jun 21, 2009 | Belkin (F5D72304F5D7000) Router
Airlink AR670W connection issues
You need to power down the modem, router and computer then turn them all on in the order - modem first, then router, then computer... Doing that and barring anything else that should work for you!
Apr 03, 2009 | Airlink AR430W Wireless Router
Wireless g router wont connect to modem
reset the router holding the button on the back by a pen for least 10 secs. and then connect it to a wired to a port and the computer. ( not the wireless) and now reconfigure with the local ip
good luck
Aug 11, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
47 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
