Short Cicuit on my Buffalo external hard disk...Help!!!!!!!!!
I just fried my External HDD.I plugged in to the incorrect voltage ...
it was 110 to 220.
i want to know if there is something to do to recover all my photos and my music...
  • foribale Jan 07, 2009
    Hi!
    Fixya!!!
    Thanx alot, i went to the store right after to buy some replacement and now my hard disk is woking !!!
    Scholar:
  • 65 Answers
First of all Hi!
This Fixya will help you solve this problem. First of all your hard drive should be still ok but you will require to open the hard drive enclosure and replace the power supply (due to the wrong voltage tapping). Please feel free to follow these fixya's not only to recover your photos but get back a working hard drive!
Solution 1: Check fuses
1. Disconnect faulty enclosure from any mains supply
2. If power supply is INTERNAL you will have to OPEN the enclosure but BEFORE you do that WITH THE hard drive UNPLUGGED TURN ON the power switch to discharge the hard drive's internal power supply
2. Open the enclosure and check for any fuses on the inside. There should be one located close to the power swtich from inside. Change it with one of a similar rating because most probably this is the culprit.
3. Try and power up the drive THIS TIME WITH the CORRECT voltage tapping
4. If the power supply is EXTERNAL you do not need to open the enclosure, just change the power supply with a similar one and you should be up and running again.
Solution 2: But the fuse is ok but there is bbq smell when i opened the enclosure!
1. Ok this means that you will need to get hold of the internal hard drive.
2. If you have another computer check if the hard drive is still ok! Here is how:
- Turn off the computer
- Open case , #
- Hook it up to the Internal IDE cable and the internal power connector
- Turn on the computer.
- You should have this detected in my computer as a new hard drive and you
should be able to see all the data in it
2. But probably you still want this as external dont you? Ok buy another enclosure from a computer shop (this time you will just need an empty one)
3. Plug the hard drive in new enclosure. If you're not experienced enough just give it to them to hoook it up for you and FINALLY you should have the reincarnated buffalo hard drive functional again.
Hope this fixya was of help :)
Best Regards
ALx
- Please take some time to rate this solution, really appreiciated thanks :) -
Posted on Jan 07, 2009
  • Alcatrazx
    Alcatrazx Jan 07, 2009
    Welcome was very very glad to help :) thanks for voting :)
My external pc drive stopped working.i under stand the Head is broken, I want to retrive important data from it. External drive is a Ministation {Buffalo} P{lease help,
You should try mounting the hard disk internally since any external HDD is actually a normal HDD in a SATA to USB enclosure. If that doesn't work , you should try finding recovery experts in your area but that might be expensive!
Nov 01, 2013 | BuffaloShop Buffalo DriveStation Axis...
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
Popular issues: problem with Buffalo Technology (HD-CE500IU2) 500 GB USB 2.0 Hard Drive My laptop is no longer recognizing the Buffalo External Hard Drive. When I plug in the USB to my laptop,
HI guys, I found a solution to a similar problem with the buffalo portable HDD that I brought from my friend. I just changed the HDD cable with the cable from Western Digital My Passport HDD and all problems were sorted out. Physically the WD cable is bit thicker than the Buffalo HDD cable. So suspect the cable is the problem. Please check if this is the problem with your Buffalo HDD before formatting. All the best
Indrajit Pande
Dec 27, 2011 | Computers & Internet
I can't Open my External Hard Disk Buffalo HD-PXT320U2/W-AP .. How can i solve this problem .. ?? The Interface view I/O Error Device .. Thamls for yOur hElp ..
I/O Error Device means that the pc cannot communicate with your external HDD - either the USB cable is broken (replace it) or its control board has failed. If it's the latter then the Buffalo is dead, get a new one.
May 24, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
When I connect my buffalo driver the yellow light flashes and I am unable to locate the external drive on my computer.. HELP!!!!
Try to plug your External Drive to other usb port or to other computer, or change the cable.
let me know the result.
dm
Mar 21, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
Buffalo hdd not detecting
Try Control Panel, Administrative Tools, Computer Management, Storage, Disk Management.
Check there to see if the drive is listed, "online" and has a "Healthy" Partition.
Dec 17, 2009 | Buffalo Technology 500GB DRIVESTATION...
Computers & Internet Logo
1,587 people viewed this question
David Payne
David Payne
