Question about Husqvarna Designer I
Embroidery hoop gets stuck to the plate and needle breaks
When stitching out a embroidery design my machine suddenly binds up and the needle breaks. I try to remove the hoop but it is stuck to the metal plate underneath. What a mess underneeth...plate is pulled off and bobbin case is compleatly pulled out and laying loose. I have to cut the nest of threads loose before I can remove the hoop. This happens about every 300 stitches! It suddenly started happening. Have used my machine constantly for two years. This problem has happened three times before when stitching out lace but I think that was a bad design. Please help! Thank you!
  • grannie_drag Feb 06, 2009
    first time my needle has ever broken dont know where the top of needle went what do I do? do I hAVE TO STRIP MACHINE ETC
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Check to see if the bobbin spring is in place. Remove the needle plate, to your right front there is a spring which looks more like an ax with handle than a "spring". It should be underneath the plate that holds it in place. If not your thread is getting caught on it and creating nesting.
Posted on Nov 27, 2012
  • 1 more comment
  • Susan Kotarski Nov 27, 2012
    And you don't need a repair man to place it where it should be, using a flat screwdriver, gently push down on the spring and it will flip back in place! Now, I am assuming your machine has a drop in bobbin that uses this type of "spring" in place..
    I have a Singer Quantum Futur and Singer Quantum XL 5000 that have this same type bobbin spring.
  • 3 Answers
This has happened to me as well. What I usually do is:-
* remove bobbin case and clean out any lint, also under the needle plate, then replace needle plate , bobbin case and the little front cover. replace the bobbin , checking that you have the thread going the correct way.
* replace the needle with a new one of the correct size for the weight of your fabric and the weight of your thread
*remove and rethread the top thread
* check that the stabilizer is of sufficient weight for the density of the design. (You may need to float an extra piece of stabilizer underneath the hoop)
* check also that it is bobbin-fill in your bobbin (it is easy to get it mixed up)
* when stitching out lace, sometimes it helps to hoop the solvy double.
Posted on Jan 20, 2009
How to stich embroidery
That would depend on if you have a regular home sewing machine or a embroidery machine. I'm going to assume that you have a regular machine.
There is something called free hand embroidery. you lower or disengage the feed dogs, take off the presser foot. Some use a darning foot and others just leave the foot off. Hopefully your design is already marked on the fabric. Place fabric in a regular hand embroidery so they fabric is right side up but the hoop makes it sit down in the rings. (make sense) Fit your hoop on the bed of the sewing machine, under the presser foot/presser foot bar. Lower the presser foot lever. (important for tension) and select stitch style and length. you may need to adjust tensions too.
Begin stitching, take a couple stitches... then reverse a couple... then snip the loose ends. Continue to stitch, guiding the hoop so that the needle follows the design. Start slowly and as you discover how your hand movements effect the length of the stitches... you can speed up and slow down as you need to create your design.
https://www.youtube.com/watch?v=ylMy6QdsZr4
Nov 03, 2012 | Sewing Machines
Cant embroider on toyota quiltmaster 50
The Quiltmaster 50 can only do free-hand embroidery. Use the darning foot. Set the machine for a satin stitch with a stitch length of 0 and lower the feed dogs. Manually move the hoop to stitch your design. (Trace the design on the fabric and place on a stabilizer if needed. Center the design in an embroidery hoop and move the hoop under the needle. In my limited experience, all fabrics need stabilizers. Some require multiple sheets of stabilizer.)
Personally, I have trouble moving any fabric under the pressure foot. This is mostly a matter of practice. You have to make a lot of scrap piece trials.
This site has the manual for the Quiltmaster 50 (European version): http://www.home-sewing.com/WebRoot/Store/Shops/homesewing/4AAF/95FA/5ED9/1505/56BA/4D44/240A/754B/QUILT50_0020_EFNI_0020__0020_679111-CEA10.pdf . See page 37 (49 of the PDF).
I hope this helps.
(who actually cheats: I either use an embroidery sewing machine or I use a late 1960s Singer Sewing machine with its Monogramming accessory. This has pre-programmed designs on little discs. That's why I don't practice free-hand stitching.)
Jun 15, 2012 | Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Apr 19, 2009 | Husqvarna Designer I
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
301 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
