Question about Evenflo Victory 5 Comfort Touch
Can't remove carseat cover
I need to wash the cover to my carseat but can't seem to get the cloth cover off the actual carseat. I can't get the straps out of the cloth cover. Is there some trick to this?
  • Anonymous Mar 31, 2014
    need to fully remove fabric for washing
There is a trick to this. All the straps are kinda connected together. The main harness is one piece, a clever clip on each of the lap section. (one on each side) needs to be removed to allow the belt to slide through the seat and cover openings. Once here the strap needs to go through the actual seatbelt buckle. Once the buckles are off you can pull the harness through the shoulder opening. The note to take here is that the harness runs through a loop on the adjuster belt (a narrower belt that runs from the back of the chair under the it to and through the adjusting fastener) Once through the loop you can pull the main harness strap free from the chair. Now the next part, depress the release clip of the adjuster and with the other hand pull this belt free from adjuster. It may require a bit of two handed work as belt nears the end. You should now have a wide belt, a narrow belt, 2x clips and 2x harness buckles. All you need to do now is remove the adjuster which usually requires the manipulation of a metal 'B' buckle which is sewn into the loop to be twisted sideways to allow it to pass through the opening. You are home free now. The cover should be elasticated around the edging and easily removed for washing.(you can also put the straps in too) Now is also a good time to just give the actual seat a good clean too. Refitting is reversal of removal. However REMEMBER and NOTE the way clips,buckles and which openings the straps went through when removing. There are usually a couple. Mark the items with a marker if you think you'll forget. On refitting you might want to put it to the next one up. (as a child grows ie. the shoulder straps should be above the shoulders when the child is seated, equally important is they must be the same on both sides.) I think there might be a couple of slots for the adjuster strap. You might want to move that one out too. Have your child seated in the chair before you start the reassembly and mark out the openings the staps need to pass through which would be most comfortable for the him/her. Good Luck.
Posted on May 30, 2007
  • Martin Heath May 30, 2007
    The adjuster might remain on the chair itself. The 'seat belt buckle release' usually has the 'B' buckle which needs manipulation through a slot.
How to remove maxi cosi cabrio harness straps
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Mar 22, 2013 | Maxi-Cosi CabrioFix (Black Reflection)...
Straps have been washe and need to know how to putr back together
Hi
The harness straps should not be removed from the carseat shell due to the safety implications of them being re-fitted incorrectly. The carseat would need to be sent to the engineers for re-fitting the harness. What country are you in and we can direct you to the relevant customer care team to discuss this with.
Feb 18, 2012 | Maxi-Cosi Axiss Reflection Booster Car...
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I really need to take the straps off our maxicosi cabriofix car seat, taking the cover off has never been a problem but i cant work out how to remove the shoulderstraps
Hi Emily - You should never remove the harness from the carseat due to the safety implications of the harness being incorrectly refitted. To wash the harness straps please remove the fabric only and wash the harness in situ using a warm water solution with lemon juice and bicarbonate of soda to clean it up .
Feb 12, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix car seat and I have washed the cover but I'm having trouble re-fitting the straps. I've looked at the website for them and everywhere on the net but no luck with instructions...
Good Evening
The harness should not be removed from the carseat. Incorrect re-fitting of the harness may cause safety implications so the carseat does need to be returned to our engineers for full inspection and repair work required.
Please contact our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm) to book it in for this. Standard charge is £50 and will include courier delivery of the product back to your address. In addition you will need to make arrangements and cover costs for the carseat to be sent to our engineers.
Jan 06, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I took the car seat cover off to wash but now I can't seem to work the straps out - can't find the manual can you help in any way?
hi
this is a similar carseat but I'm sure that this manual should give you the right idea of how they go back in
http://www.chicco.com/Portals/0/Products/Pdf/Istruzioni_Key1%20X-Plus%2063251________.pdf
most carseat now have this fitting
Oct 19, 2010 | Chicco Shuttle Infant Car Seat
Evenflo carseat,can't figure out the straps after washing
You need to put the straps throught the bottom, then the top openings you put it through the 2nd **** or where the baby will be comfortable. Then you tie it on the back.
Jun 17, 2009 | Baby Gear
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Need Extension Straps for 2007 Maxi-Cosi infant carseat
hello boss why dont u contact the same place where u have bought the carseat earlier(4 months back).. i guess he can be very help ful to u..
Feb 11, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Evenflo Victory 5 Comfort Touch Logo
1,539 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
