Question about Whirlpool Duet GHW9150P Front Load Washer
My whites are not comming clean and are not a bright white
My whites are not comming clean no matter how less or much soap, bleach I use or how many times I rince them. The stains are not comming out and my socks bottoms are not comming out white they look dirty. My whites are not the bright whites I had with my old washer. I use not water to wash and rince with. I use tide and add clorx. I have a water softner too.
I don't know if this is a solution to your particular problem but when we wash whites, first, we wash them twice,with hot water, second, we dont use bleach!!! (this will eventually yellow them). Third, we dont use liquid softner. For the whites we use a softner sheet in the dryer. Since we started to use this procedure I have noticed a marked decrease in areas such as under arm stains in white under shirts. I have some that are 2 years old and have no stains or yellowing like this. Hope this helps
Posted on Jan 08, 2009
We use well water . after washing tower 2 or 3 days of use tower it starts to smell musty .how do we prevent this?
If the machine has a "clean washer" setting, run that with 2/3 cup bleach only (no soap). If it doesn't have a specific setting to clean the machine, run a small load with hot water and use 2/3 cup bleach, no soap.
If you're asking how to avoid the problem altogether, you'd most likely need to install a water softener, or water filter.
Mar 17, 2015 | Kenmore Elite 45986 Front Load Washer
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
May 03, 2017 | LG Washing Machines
Is there any way to make white clothes less dingy when using an H.E. washer such as the Kenmore Elite? I've tried cleaning the washer once a month, using a little OxiClean with the detergent, using bleach...
Try nappysan. As you have found out bleach is no good. In the "day" we used to use a "Bluing" Agent, see if you can get those, My solution is to use just a dot or 2 of Dawn dish washing liquid on any spots I thought would stain-scrub them for just a minute with a fingernail brush. Then I would fill my washer about 1/4 of the way with straight hot water & add a 1/2 c. of automatic dishwasher soap to the tub--the cheaper the better because most cheaper brands have more phosphorous. I'd swish the water around, turn the temp. to warm, & put in my whites when the tub was about halfway full. Then I'd add about half the amount of detergent to the tub that I would normally use.
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
Duet washer is stinky.I leave the tub door and the soap dispenser door open when not in use. Even so, epecially after doing several loads in a row I have a very stinky machine There is mold growing on the...
are you on a well??
do you use bleach in with your whites??
some well water untreated can cause exceptionally stinky machines, especially if no or very little bleach is used during white washing..
usually if you use bleach in with your whites in normal amounts and leave the door open in between uses there should be very little stinky odor or mold growth.
the mold growing on the gasket is a sign of to little bleach or none being used, and/or a really damp environment for the unit to reside in.
they do make several cleaners designed just for stinky front loader washers..
they might help..
i've been using a front loader for 13 years, leave the door ajar between uses, and use bleach in every white load and have had no issues with stinky unless i or someone else doing wash forget and close the door for a couple days, then it gets stinky but goes away after white load with bleach and hot water..
hope this helps,
best of luck,
ttfn
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Also can't get whites clean in out front load washer
try using a bit of automatic dish soap in with the detergent and bleach .Ifound that to do wonders
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bleach ruins colored load done after white load
Your bleach dispenser is the problem. It needs to be replaced. All of the bleach isn't leaving the dispenser so when you go to wash your colored clothing what's left in there comes out. Best thing to do till you fix it is wash your whites last. You can try running some white vinegar through the wash on the hottest cycle. Pour the vinegar into the bleach area and the soap area and run it on hot. Run it a couple of times. If there is anything clogging up the dispenser this might clean it out. Let me know if you have any other questions and good luck.
Oct 18, 2008 | Whirlpool GHW9300 Duet Washer
Usage of HE detergents
The best he soap I have seen yet is all, he is high effieciency low suds soap. The rule of thumb for liquid he soap is 2 Tbl for every 1 Tbl of softener. Powder can be used but is not good on pumps and build up in tubs. If you have a water softener you can use 25% less soap. Still with powder you need about a 1/4 cup per load to equal a 2 Tbl liquid variety. Suds damage pump impellers, seals and hoses from expansion and that is it on the reason "why to use he".
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Won't bleach clothes
Check to make sure your soap is not sudsing up if you see alot of foaming in the machine when in use switch brands. also i reccommed running the machine a few times until all suds are gone. Most users of frontloaders put way to much soap and bleach in these machines they use alot less water so you can use alot less cleaning products. Also these machines will sometimes give you a faut code if this comes across the led write it down and let me know what code came out.
Sep 25, 2007 | GE WSXH208A Front Load Washer
White Clothes even with bleach and hot water don't get clean???
i have used everything to solve this exact problem!  I have to say the best detergent or bleach i have used in the lg..is the purex with bleach for colours it seems to work better than anything ive used...spent a fortune to have to soak my whites before putting them in this washer.  I must say im disappointed..
May 06, 2007 | LG WM1814CW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
164 people viewed this question
Dan Webster
Dan Webster
Sal De
