Question about Frigidaire ATF6000ES Front Load Washer
Door lock doesn't release automatically; clothes still very wet
Washer bought for Christmas present to Mom. After 3rd or 4th load door stays locked @ end of cycle. Button "pause" pushed; door opens, but clothes are soaking wet and water standing in drum. This is second washer since Christmas; first one did the exact same thing. Store replaced it thought the problem was in the washer.....
  • 93 Answers
You need the Factory Repair Manual for your Affinity Washer. There is alot that can go wrong with these machines and you will need to run the washer through its diagnostics.
Here is a Link where you can Download the Affinity Washer Repair Manual
Posted on Jan 09, 2009
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Door is open, lock is engaged.
Solved - installed new door locking assembly.
Sep 18, 2009 | GE Energy Star WCVH6260F Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Philips Whirlpool 400 AWG 370 door is locked
take the kick panel off and reach up the right side where the door lock is. there is a release pull down that releases the door.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
247 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
