Question about NEC XT41LH Projector Lamp for XT4100, SX4000, SX4000D, HD4
Lamp Error after replacing lamp
XT 4100 projector gives LP error code...even after replacing projector lamp.
  • 4 more comments
  • lance384 Jan 09, 2009
    All connections checked, new lamp is seated correctly/properly. Lamp is good, verified in identical projector. Can the "LP" error code mean something else besides replace lamp?
    Using manufacturer's specified model/part number for replacement lamp; not a third party product.
    All of these actions have been taken:
    Check connections
    -Clean dust
    -Reconnect Lamp
    -Restart the Projector
    Same indication: "LP" error code.
    lamp alignment problem.rearrange the lamp fittings properly to solve this problem.
    Verified alignment, still no change.
    If lamp cover is not seated / fixed properly then you will get error. Replacement Lamp should be original and not aftermarket.
    See previous replies.
  • lance384 Feb 03, 2009
    Problem resolved by my internal staff. Lamp hours have to be reset, which is done by holding the 'menu' button for 10-15 seconds upon start up. No further assistance needed. thanks to all for their responses.
    Genius:
  • 1,239 Answers
HI
1. Check the cable outlet
2. Check for damage of power cable
Posted on Jan 09, 2009
  • 91 Answers
Don't you need to reset the filter meter after replacing the bulb? I have a haitachi projector and that was what we had to do.
  • 10,594 Answers
  • Shahid Electronics
    Shahid Electronics Jan 09, 2009
    I saw previous replies. I'm talking about Lamp Cover, which press special safety switch in projector. Please recheck lamp cover as many times I saw people do not place it properly then get error in projector.
    Sergeant:
    Novelist:
  • 326 Answers
Lamp alignment problem.rearrange the lamp fittings properly to solve this problem.
Posted on Jan 07, 2009
  • NEC Master
  • 13,433 Answers
Is the replacement lamp the same model and supported by the projector? some 3rd party lamps may produce too much heat or not function properly.
-Check connections
-Clean dust
-Reconnect Lamp
    Genius:
  • 1,550 Answers
Check whether the lamp is placed properly in the projector . Check the internal connection .
DMD error code
the DMD is good ,
the Projector will still start up,even if the DMD is defective.
the lamp ballast or the mother board is defective
Feb 20, 2014 | Vivitek H1080FD DLP Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
In Focus LP 640 won't even turn on? Any help
There are several reasons this could happen, and can usually be identified by glancing at the Power LED. The following applies to this particular projector:
1) Blinking RED led- Lamp or fan failure. Usually this is a bulb issue and simply needs the lamp replaced and the lamp life hours reset. Below you will find an image from the owners manual that will allow you to translate the # of times the LED blinks into a problem/solutionrobertsager.png
2) Solid Red LED means unidentifiable error. You will need to contact customer support at that point to schedule service.
Mar 07, 2011 | InFocus LP640 Multimedia Projector
My nec vt48 projector gets hot and turns off. It gives off 3 beeps a few seconds after
This problem and the error beep codes indicate a lamp that needs to be replaced. The correct part number for the lamp is VT85LP. Basically the lamps are rated with a life expectancy of 2000 hours. At the 2001 lamp hour (3001 in eco-mode) the LCD projector will power on, but not display an image, due to the indicator requesting the lamp be replaced and the lamp hours reset (hold the help button on the remote for 10 seconds when powering it on).
Aug 19, 2009 | NEC Office Equipment & Supplies
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Failure to print
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
May 21, 2008 | Samsung SCX-4100 All-In-One Laser Printer
LT 157 projector
reset the lamp timer.
Oct 15, 2007 | Office Equipment & Supplies
Dell 3400mp Lamp error.
Inside the shell that holds the lamp assembly the bottom of the lamp power connection had shifted out of position in the bottom of its harness. I had to remove the projector top to firmly reseat the bottom power connector in the correct vertical position in the harness.
Sep 02, 2007 | Dell 3400MP Multimedia Projector
62 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
