Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
No Video I ordered a new Hyper Module (MVPU14)and installed it. I was getting wavey lines for the first 10 min. after turning the set on. I was told the hyper module was the cause. After installing the module I no longer get any video at all. Sound works fine but no video,no menu display nothing. Is there something that needs to be reset? I was very carefull soldering the ground posts.
  • Mark McFadden Jun 07, 2007
    You was Right! I found flux residue around the tabs. after cleaning the board the set works fine. Replacing the hyper module cleared the wavey lines. The set works like new.
    Thank You
  • 934 Answers
The VVPU14 hyper module in that unit is a trickey installation because they have their can tabs soldered to the motherboard and next to each of the solder points on the pad are fine wire traces on top and bottom of the board that can easily be broken or over soldered... Check there first, with a fine magnifier. To answer your question, no, there are no resets or anything else you need to do to after the H/M install. Good Luck. Bill
Posted on Jun 05, 2007
SOURCE:
Toshiba hyper module. Vertical lines on screen.
change the 10 or so surface mounted bad filter caps in the Hyper module this set uses--the board is no longer available--it can be sent out for rebuild (not toshiba) but that is rather costly (200+)
Oct 28, 2012 | Toshiba 57H81 57" Rear Projection...
The picture is wavey tried everything and i am unable to fix can u help me?
The hypeboard has failed. There are about 12 capacitors (surface mount) that need to be replaced. Unless you have very good soldering skills you shouldn't attempt the repair. The hyperboard will be marked with MVPU14 I believe. It should be located directly behind all your input connections in enclosed in a metal can. It is about 8" inch square module that plugs into the signal board.
The metal housing will need to be unsoldered from the signal board, before you can remove and service the hyperl board.
Feb 19, 2011 | Toshiba 50H82 50" Rear Projection...
50hdx82 video shaking
It is the Hyper board gone bad. There 11 10uf 16v cap's that go bad. They are very small surface mount type 4mm in size. They are cheap but hard to solder in. There is a guy on ebay who is rebuilding them for $75. Just search this part number: MVPU14 that is the hyper board.
Feb 08, 2009 | Toshiba 50HDX82 50" Rear Projection...
Picture problem on Toshiba 42inch WH36 series
These capacitors are on Hyper Board. You have to replace in order to fix the problem. See the link: http://www.diyforums.net/projection-tv-lines-1327.html
Apr 17, 2017 | Televison & Video
Toshiba 42H82 problem
bad capacitors on the hyper module. there are 11 surface mount capacitors that need to be replace and that should fix it. the caps themselves only cost around $14 for all of them together
Jan 05, 2008 | Toshiba 42H82 42" Rear Projection...
Shakey Screen
That problem is caused by defective capacitors on the Hyper Board location UZ01 stamped MVPU14. You will need to have a technican remove the board and replace all the 10 uF @ 16 Volt SMD caps p/n 24619040N found on that board. The Hyper board is no longer available as a part.
Dec 24, 2007 | Toshiba 50H82 50" Rear Projection...
Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Oct 20, 2007 | Toshiba 57H81 57" Rear Projection...
Wavey Picture
The hyper or scan converter module is bad in this set. You can certainly have this set repaired and will run about 275 to 350 depending on where and who does the repair. Good Luck
Apr 08, 2007 | Toshiba 42H81 42" Rear Projection...
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
