Memory upgrade, Philips X59.
Where is the secound memory slot?
  • John Goodwin
    John Goodwin Jan 07, 2009
    Sorry but I'am looking for the second memory slot on a Philips X59 laptop. The one that is easy to see is as in most cases can be got at from the underside Hard-drive cover. There is a second slot for a further max 1gb somewhere else and think it maybe under the keyboard. But how do I get to it.
    Genius:
  • 1,913 Answers
Open the cpu coner u see neare processor 2 or 4 memory bank slot.those are straight near processor
Posted on Jan 07, 2009
Philips Freevents X65 - how do I access memory slots to upgrade
Most times the memory slots will be on the bottom of the laptop. You just remove the power cord, remove the battery then remove the screws to the cover that houses the memory. Look for little icons on the cover, the circular discs will be the cd drive and the hard drive. The memory cover icon will have a jagged square on it.
If the memory is not on the bottom of the laptop then it will be located under the keyboard and palmrest area which means you will have to take them apart to get to it.
Jun 05, 2012 | Computers & Internet
How do you access the memory slots on an acer aspire z3731
Memory Sockets or Slots are the place where memory RAM modules are inserted in the motherboard. The Acer Aspire Z3731 has 4 (4 banks of 1) memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
Mar 09, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
Whats my sdram capacity
HP Pavilion 9694C memory upgrade specification, Pavilion 9694C maximum memory, memory speed, and memory upgrade options. Upgrade memory on HP Pavilion 9694C upto a maximum of 256 MB
PC100/133 SDRAM DIMMs, with maximum 128MB per slot in 2 memory slots. The HP Pavilion 9694C takes the PC100/133 SDRAM DIMMs Memory Type.
Hope that helps.
Feb 16, 2011 | HP Pavilion 9694C PC Desktop
Would like to upgrade memory up to 2 Gb, found one slot only . where in the 2nd
There are two memory slots on your computer, one of which is occupied by standard memory. You can upgrade memory by installing a memory module into the available slot.
Installing memory
Follow these steps to install memory:
1Turn off the computer, unplug the AC adapter (if connected) and remove the battery pack. Then turn the computer over to access its base.
2Remove the screw (a) from the memory cover; then lift up and remove the memory cover (b).
50 2 Customizing your computer
3Insert the memory module diagonally into the slot (a), then gently press it down (b) until it clicks into place.
4Replace the memory cover and secure it with the screw.
Jan 08, 2011 | Acer TravelMate C110 Tablet PC
Philips freevents x59 fan does not start causing the laptop to overheat.is there a bios setting for this? If not how do I fix this?
You have to press F2 when you start your laptop. Hope this helps!?
Please rate solution - Thanks
May 15, 2010 | Computers & Internet
Where are the memory slots on a dell xps m140 laptop?
One memory module, ('Stick') slot is located on the bottom of the laptop, in the Memory Compartment. (Has two Philips screws on the cover, and is located close to the battery release button)
The other memory module goes under the keyboard.
Here's how to replace them from Dell Support,
http://support.dell.com/support/edocs/systems/xps140M/en/sm/upgrades.htm#wp999869
Sep 02, 2009 | Dell Inspiron XPS M140 Notebook
How many memorry slots are there in philips x59 laptop, where can i find them? i am looking for upgreading its ram.
It has one slot - this is located on the underside of your laptop chassis in the middle you will see a small 2cm x 3cm plastic cover, under this are the memory banks.
Jul 31, 2009 | Computers & Internet
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Memory upgrade
The M45-S169 only has one available memory slot.
(I'm confused about your post that states "M45-S265" in the head line).
  • Configured with 512MB DDR SDRAM (both memory slots may be occupied)
  • 512MB(min)/2048MB (max), 256MB on-board memory with 1 available memory slot for 256MB, 512MB, or 1024MB PC2700 DDR 333MHz SDRAM 2.5V SODIMM memory modules
You can find the complete specifications here.
Jan 05, 2009 | Toshiba Satellite M45-S265 Notebook
How to upgrade memory
The NEC Versa m500e has 2 memory slots. Each slot can hold DDR PC2700 with a maximum of 512MB per slot.
I'm not sure where the memory is located on the Versa, but normally in the middle on the bottom of the laptop there is a memory slot. on some units the memory is located under the keyboard, so you have to remove this first to change the memory.
Hope this helps
Dec 27, 2007 | NEC Versa FX Notebook
Computers & Internet Logo
307 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
