I have a RCA4258 remote and a Toshbia tv. I lost my code list. Where can I get code?
Hi! The codes of your remote control for Toshiba TV are 1011, 1017, 1018, 1042, 1054, 1090, 1091, 1094, 1097, 1100, 1103, 1107, 1110, 1122, 1191, 1192, 1209, 1214, 1265, 1266, 1279, 1290, 1294, 1300, 1305, 1306, 1311, 1314, 1323, 1344, 1346, 1353, 1369, 1381. If in case none of these works you can try doing manual search and these are the steps.
1. Manually turn on the TV.
2. Press and hold the TV key. The LED turns on and remains on. Keep holding down the TV key.
3. While holding the TV key down, press and hold the POWER key. The LED turns off. After holding down both keys for three seconds, the LED turns back on.
4. Release both keys. The LED remains on.
Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the TV you are currently programming the remote to control.
5. Press and release the POWER key repeatedly until your TV turns off. Each time you press the POWER key, the LED blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been tried. If your component turns off, you have
found the correct code. (If it cycles through and the LED blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.)
Because there are so many codes, you may have to press the POWER key many times—possibly hundreds of times.
6. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The LED turns off. You must press the STOP key to save the code or the correct code will not be stored! When you press the STOP key, the code is stored.
