Question about Nikon Cameras
Camera flash problem (Nikon)
I use a Nikon D80. I have tried setting the camera menu so the Speedlight SB 600 flash works off camera without the in-built flash working. Thus far I have had no luck. Can you help me please??
  • 1 more comment
  • pturnill Jan 07, 2009
    My Speedlight SB 600 is of camera being used wirelessly, the in built flash is up but firering when it shouldn't.
    pturnill
    Hi randy320sgi,
    Thank you for your thoughts but after reading through what you have said and what the manual tells me, the built-in flash does not switch off when in the M,P,S and A modes. It will only switch off in the other AUTO modes. I am now at a loss!!
    pturnill
  • Randy Wheatley
    Randy Wheatley May 11, 2010
    pturnill,
    Do you mean it still pops up while trying to use the Speedlight? Or are you trying to use it remotely? You switched to flash settings correct?
    rnay320sgi
    Novelist:
  • 121 Answers
Ok,
try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
randy320sgi
Posted on Jan 07, 2009
Why does the flash on my Nikon Speedlight Sb-600 flash twice before it takes the actual picture?
It's called a pre-flash. It's so the camera can judge the settings needed for proper exposure.
Nov 21, 2010 | Nikon Speedlight SB-600 TTL Flash
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
May 17, 2010 | Nikon Speedlight SB-22S TTL Flash
Sb-600 and d80 sync, connecting, off camera..
  1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
  2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
  3. Set the flash mode to Master (do not set it as AA or A)
  4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
  5. On the D80, from custom settings menu, select Built-in-flash
  6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
  7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
  8. Set the channel to the same as in step 4
Now you are ready to use the remote off-camera flash.
Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
SB-600 Nikon speedlight
You can download a PDF from www.nikonusa.com (www.nikonusa.com/pdf/manuals/Speedlights/SB-600.pdf) and print it out.
Jan 16, 2009 | Nikon Speedlight SB-600 TTL Flash
I Have a Nikon d80 with a sb800 speedlight
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Nov 15, 2008 | Nikon Speedlight SB-800 TTL Flash
D80 and SB-600 FV Lock doesn't work anymore
In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
Also, reset you flash by turning on the power and removing the batteries and re-install them.
Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Settings for sb-800 to control external sb-600
set the SB-800 as the commander and SB-600 as the slave. Press and hold the mode button to open up the menu and select the options.
Mar 25, 2008 | Nikon Speedlight SB-800 TTL Flash
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Noise while zooming with sb-600
sb-600/800 make a distinct motor-spinning noise when zooming, this is normal. Any grinding/clicking noises are not normal.
Jan 25, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon d80 continuous mode
This can be that the flash sync speed of the camera is not correct. There may not be enough exposure from the flash to the subject during the opened curtain (shutter) sequence.
Jerry G.
Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
Cameras Logo
193 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
