Question about Toshiba e-STUDIO 50F Plain Paper Laser Fax
Increase rings on fax machine
I am trying to increase the rings on our fax machine. It is hooked up to our phone line.
  • schneider_38 Jan 07, 2009
    This is for a Toshiba E-Studio 50F model. Lost our manual and would like to know how to change the rings to 5. Thank you....
  • Toshiba Master
  • 643 Answers
Above the start button, there is a UP arrow button which is for increase of ringer volume, just press repeatedly to increase the volume. The down arrow is for lower down the ringer volume.
Posted on Feb 26, 2009
Mesage displayed is "phone off hook"
  • You need 2 lines if you phone rings. You had to wait till it doesn't ring to send fax. To do both thing you need 2 phone lines.
May 14, 2014 | Panasonic Panafax DX-800 Plain Paper Laser...
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a panasonic fax machine. It will receive
if this is to every line then you have a bad main board or your ringer waiting period needs to be increased... (meaning the amount of times it rings before pickup...
Dec 10, 2009 | Brother IntelliFAX 4100 Laser Fax
My fax machine is hooked to my main line, how do I keep my fax machine from picking up all my calls? Do I have to set my fax to more rings?
The only real solution is to have a different number/line for your fax or a special phone exchange.
If you're just having problems getting to the phone in time and you're not worried about people leaving voicemail you could increase the number of rings to the maximum but it will still intercept anything that hits that point.
Probably not what you were hoping to hear but unfortunately it's not a high powered system.
Hope it helps.
Martin
Oct 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Machine shows "phone off hook"
Hi there
check where your phone cale goes into the machine you will proberbly find two sockets one marked phone and one marked line the phone line needs to go into the one marked line and a phone handset in the one marked phone if this is correct try ringing yor line that the fax is plugged into see if you get a ring or engaged tone if you are getting engaged unplug the fax and try again if this now works the chance is that the modem board in your fax has failed and will require replaceing
Regards AL "alstech"
May 18, 2009 | HP Officejet 5510 All-In-One Thermal...
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a discontinued phone and have lost the instruction book and need to figure out why the fax machine is not letting the answering machine pick up.
you have both the fax machine and the answering machine on the same phone line.
The fax machine and the answering machine are set to answer in a certain number of rings.
In your case the fax machine is set to answer the line in less rings than the answering machine. You have to increase the number of rings of your fax so that the answering machine will work.
Aug 06, 2008 | Lands Phones
Problem with the F/T setting.
leave these phones unused for one day and then use it and see.
leaving them unused will make everything get settled.
Jul 29, 2008 | Office Equipment & Supplies
Will not fax
Hook a phone to the fax line and try to dial out... a fax line is no different than a phone line at your house ,, don't use a multi line phone like the ones at the office use a phone like you would have at the house to hook the the fax line .. If you are able to dial out call someone and check the line for static and pops they can cause the fax not to work either.. Good Luck
Mar 31, 2008 | Ricoh 2050L Laser Fax
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Toshiba e-STUDIO 50F Plain Paper Laser Fax Logo
162 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
