Question about Sony KP-51HW40 51" Rear Projection Television
Sony It was turning blue then the screen shut itself off. the sound was ok. I will try it again with the menu button when i get home. I will e mail you with exact info this afternoon. thank you so much. Karen
  • 1 more comment
  • lthrgal44 Jan 07, 2009
    Hi- I just checked, when i turn it on, the screen is blue. i hit the tvs menu button and it showed for a second then went all blue. there are small lines in the blue. the sound also came on for a second, then went off. then the tv will shut off.
  • Anonymous Jan 11, 2009
    when i turn it on the color is green with horizontal lines,this is for a few seconds only then it shut off.
  • artemonil Jan 11, 2009
    when i turn it on the color is green with horizontal lines,this for a few seconds only then it shut off
I've had similar problems in the past with my tv. What worked for me was taking off the front panel to get access to the tv that way. There is a little black box on the front, right, side that has 6 screws on it (2 rows of 3). I think the top row adjusts the focus for each color tube and the bottom row adjusts the power going to each color tube. My tv would turn on blue for a few seconds then shut itself off because the blue tube was getting too much power. I turned down (counter clock wise) the screw that corresponded to blue tube and it worked like a charm. Might have to play around a little bit to get the screws at the right level so that the tv stays on while still getting enough power to the tube to have the screen look right. If the problem is with the red or green the solution is the same, just with the corresonding screw. Hope that helps.
Posted on Jan 14, 2009
Nook troubleshooting
You have tried all the usual resets?
Turn the NOOK off completely.
Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds).
Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm.
However that said, it sounds like you have a hardware fault, maybe screen connector or screen itself. Not really economically repairable in my opinion
Jun 23, 2014 | Computers & Internet
Picture problem
Have you try to unplug the unit for a couple of hour, then plug it again.. thhis is to reset the unit itself..
thank you
May 29, 2008 | Hitachi 55HDT79 55 in. Plasma HDTV
Try this to play DVD movies on your PS2 if it wont play DVD movies.
If your PS2 works fine with Games and just wont play any DVD movies at all.Then you should try this trick to play movies on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:894e4e5.jpg
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like3aef030.jpg
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the movie plays itself.If your lens is good then it will play DVD in first go else try again till it PLAY your DVD movie.
Thank you!
on Nov 29, 2009 | Sony PlayStation 2 (PS2) Console
Mitsubishi 55" MODEL WS 55513 1080 HDTV blue screen
I plugged my Dell desk top in and the XP screen comes up, but when windows comes on I getablue screen. Any ideas?
Jan 21, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My computer starts to boot then once it is completed the a message comes up saying there is an error and then a blue screen comes up and reboots itself. THis continues and does not stop
When starting up, press the F8 key to catch the Boot Menu. Select the option to disable automatic restart on system failure. Boot and when it fails the Blue Screen will remain for you. Look near the top and see what file has been identified as the failure i.e. NV4_disp.dll. (Google the file name to see what program or hardware the failed file is associated with) Press and Hold the power button to shut down. Turn the computer back on and press the F8 key again to catch the Boot menu, and select Safe mode. If allowed into Safe Mode, try to go into Device Manager and either disable the failing device, or remove the associated program. If this doesn't work you can try to do a system restore to a date before this error started to appear. If you post back the file causing the blue screen, I can instruct you further.
Jan 10, 2010 | Fujitsu Computers & Internet
You need to a fresh restore of the iPhone. Hold down the home and power buttons together until the screen goes black. Then while the screen is still black, plug it into your computer WHILE holding down the home button.
At this point iTunes should detect your iPhone and tell you that you need to do a restore.
Hope this helps!
Please rate me!
Jul 09, 2009 | Apple iPhone Smartphone
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Dec 23, 2007 | Vizio L37 Television
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Dec 02, 2007 | Pioneer DV-366K DVD Player
Sony KP-51HW40 51" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
