Question about Ecoquest Breeze AT Living Air Purifier
Unit has power but fan does not operate.
Eco quest Breeze - less than 2 years old.
  • Dutch7773
    Dutch7773 May 11, 2010
    how do you know the unit has power, have you checked the fuse?
    I would need a little bit more information.
    Eric
  • 520 Answers
There is a micro switch that the metal rim of the filter that must contact in order for the fan to run tha unit to run. a bend or warpage in that metal filter housing will cuase contact problems with that switch causing it not to run
Posted on Jun 22, 2009
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
How do i clean the eco-quest air purifier? Mine is the Breeze AT model.
take the back filter off and blow out the dust really well a q_tip may help with the tight spaces that will be a very tedious task check owners manual too
Nov 18, 2010 | Ecoquest Fresh Air Air Purifier
MIDI Ionic Breeze quit working
Unit seems to need reset...To do this simply, with unit still plugged in, set to off by selecting on button until there are no high, med, or low lights on. unplug unit from wall for about 15 seconds then plug back into wall socket and select your favorite setting high, med. or low. The order in which you perform this task must be as stated above and the unit must be clean and the door and cleaning rod must be in home position. Hope this helps, mines working fine now but took a couple tries to find right order to reset.
Sep 16, 2009 | Sharper Image Professional Plus Ionic...
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
Eco quest Breeze AT - Air purifier -Voltage varying, going haywire, unable to adjust controls
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
May 27, 2009 | Ecoquest Breeze AT Living Air Purifier
Ozone function causing blue spark and snapping
Contact healthytech@triad.rr.com. They will be glad to help you.
Apr 13, 2009 | Air Purifiers
I need to clean my Eco Quest Living Air purifyer plate...
clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
Mar 01, 2009 | Ecoquest Breeze AT Living Air Purifier
Lights won`t work,buttons on front and remote will not change the motor speed,stuck on low,ECO Quest Breeze AT.Thank you.
Did anybody solve this for you? The same thing happened to mine! All purifier lights come on but it's stuck on low!
Sep 18, 2008 | Ecoquest Breeze AT Living Air Purifier
GP Professional Series Ionic Breeze - Simply Quit Working
Sharper Image models are no longer supported because they have been recalled since they were proven to be ineffective.
Here is a link about the Chapter 11
Here is a link for the EPA about ionizers
Jul 06, 2008 | Sharper Image Professional Plus Ionic...
Ionic Breeze Professional Series Table Top Model
you need to clean the unit entirely, but be prepared, it will eventually do it again and again until it finally stops working all together. I have sent three back in one year and now they won't do anything since itis longer than the 1 year warranty. No wonder theyare bacnkrupt; selling worthless ****!!
Mar 09, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Ecoquest Breeze AT Living Air Purifier Logo
260 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
