Center channel speaker output problem
Center channel speaker output is faint and distorted. All other speaker outputs work fine. The problem is not the speaker connected to the amplifier.
  • Chris Jan 08, 2009
    The speakers all work. The amplifier is the problem.
  • Chris Jan 09, 2009
    Sony STR-D715. Has anyone repaired this amplifier for this problem?
    Sniper:
  • 51 Answers
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Posted on Jan 08, 2009
  • Srinivas
    Srinivas Jan 09, 2009
    Which Amp Are you using Currently??
    Tell me Details.
  • vivek verma
    vivek verma Feb 22, 2014
    mercury 2.1 980 watt
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
Pioneer SA100 integrated - low, distorted output
At this point, I would be looking at the main power suply for the final output stage. You may be attempting to drive the output with the driver section rather than the final amp stage. The center pin of the output transistors should have B+/B- on them. Measure that to ground and report the value here.
Dan
Jul 12, 2010 | Pioneer A35R 2-Channel Amplifier
Yamaha RX-V365 Receiver when I hook up my center channel it is not audible at all. The R and L speakers work fine when they were located in the FRONT A and FRONT B terminals, but when I moved everything to...
With what signal did you try? Maybe your signal source (DVD/TV or radio) didn't contain any sounds for the center channel.
Go to the Setup menu, Speaker setup / Manual setup and find there item called "Test tone". It will output a test tone to each speaker individually (you will see on LCD which speaker is being tested at each moment). If you will hear a sound from the center now, there is no issue and center is working fine, just your source didn't contain any sound for the center.
If it doesn't work, then either you have faulty cable, faulty speaker or faulty center output of the receiver.
- Try connecting the center speaker to different output of receiver (this will test if speaker is OK).
- Try connecting working LEFT speaker to left output with CENTER cable (this will test if cable is OK).
- Try connecting working LEFT speaker with working cable to the CENTER output (this will test the output of receiver if OK - but use the Test Tone from Setup).
May 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Problem with philips Powerhouse AW626 music System
try to invert your speakers cables and connect your right speaker cable to left output if the problem still happened you will have a problem in your amp and ask for help from good service center near you-------if the problem disappear you will have a problem in left channel----cable or speaker.
Jun 03, 2008 | Audio Players & Recorders
Distorted and low volume voices - Mr French
hi, first u will have to determine if the center output is bad or the cntr speaker is bad, to do so do not disable the center, simply remove the speaker wires and check if there is noise, if not means speaker is bad, if still noisy then output is bad,u will then need a technician to get the job done.. letr me know..
Jan 26, 2008 | Infinity CC-1 Center Speaker
326 people viewed this question
 Grubhead
Grubhead
