Question about Alesis RA-150 Amplifier
Amp not powering up
I recently got an alesis ra300 but like many others there was a faulty relay unit. I replaced this with an 8 a instead of the 10 a one. However I think when I replugged the cables I plugged the right input into the output section and vice versa. When I turned it on it started to power up for about 2 seconds before the fuse went. I replaced the fuse and switched the cables to how they should be but it's still not powering up at all now.I'm wondering where the fault may lie is it in the transformer? if so how can I fix this problem?
  • 85 Answers
Chek transfomer with a multi meter set on continuity,check primary input across wires AMPLIFIER MUST NOT BE PLUGGED INTO WALL SOCKET...check outputs low readings in ohms are good no readings mean open transformer(buggered
I suspect outpuit stage short as this probably buggered relay in first place
Posted on Jan 08, 2009
Hello. RA300 used only in a studio environment, never pushed hard. During a mastering project we lost one side of the amp. Thanks!
The first things to check are the devices on the heatsink. They do all the work so tend to go when pushed! Remember stereo amps are just two amps put together, so at least you have a good channel (which is the same as the bad one) to do tests with say an ohmeter.
Apr 27, 2011 | Alesis RA-150 Amplifier
I AM LOOKING FOR A N ALESIS 8 CHANEL MULTIMIXER THAN CAN BE USED WITH 220V
Since this unit uses so little power, I would recommend a small stepdown transformer. A 20 or more Watt one is sufficient. DO NOT use a convertor that is intended for appliances like hair driers.
Here is a link... the smallest would work and costs $8... I don't know how they can make them for that. You might consider getting a bigger one if you get other equipment to run as well.
Finding the special power adapter that uses 220 and is compatible to the Alesis would cost much more.
Mar 14, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
I have an elesis RA 500 it blows the slow blow fuse when i plug it in .any ideas what is wrong?
hi there,
it sounds like the internal transformer has gone.
It's not user replaceable and will require you to take to an electronics store to be repaired.
SAME THING RECENTLY HAPPEN WITH ONE OF MY BITS OF KIT ...... for heavens sake don't just keep changing the fuse time and time again.
Jan 07, 2011 | Alesis RA300 Amplifier
Alesis RA 500 makes a "clicking" sound and no more sound. later it will "click" on again
Clicking sound is a protection relay. This means one of the power amp sections have failed. Or that your speakers connections are faulty
Sep 24, 2010 | Alesis RA300 Amplifier
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Mar 28, 2010 | 1993 Isuzu Rodeo
Power up problem with alesis rs300 (ra300)
you have more than likely damaged some transistors.
the resistors have burned because of excessive current.
there are 2 typesof transistors,bipolar and mosfet
a bipolar transistor has 3 pins.1) base 2)emitter 3)collector.
an NPN is tested with the + meter lead on the base , and a PNP transistor with the - lead on the base.
TESTING
base to collector should read .5 to .6 v drop in one direction and open in the other with a digital meter on the diode check function.
base to emitter about the same,but slightly higher than the collector.
if base to collector is .5v then base to emitter is .52 or so.it is always higher than the base collector number.
between emitter and collector will read open in both directions.
if there is a short on any lead combination,the transistor is blown.
npn transistors operate on the positive rail power supply,and pnp on the negative rail.
typically a 150 watt amp will run + - 65vdc.
the transistors running on the plus side are npn and on the negative pnp.
most pnp output transistors are green.,but some are black,
so we must go by the numbers on the transistors, eg.A1076 is a pnp,B755 is a pnp and all transistors that have a C or D eg. D424 are NPN transistors. all A and B numbers are PNP and all C and D numbers are NPN.
MOSFET transistors have 3 pins 1)gate 2)drain 3)source
the source goes to power like the collector does. the drain is like the emitter,and the gate switches it on like the base does.
testing a mosfet is a different procedure.
a mosfet with k then a number e.g. k135 is a positive device like npn.
a mosfet with j and a number e.g. J50 is a negative device like pnp.
a mosfet reads open source to drain both directions.
for a positive (k number device) the plus meter lead goes on the source.,the black meter lead on the drain. on the diode test function.
jump a wire from the source to the gate for 1/2 second and remove the jumper while leaving the other two meter leads connected to the source and drain.The mosfet should switch on and the meter should show a short.that means the mosfet switched on.About 5 seconds later,the resistance from drain to source should go open.
for a p channel mosfet,it checks the same,except that the black meter lead goes on the source and gate .
a mosfet will stay switched on longer than the voltage applied to the gate,if it is driving a high impedance device such as a meter.
a bipolar transistor will not stay on when voltage is removed from the base lead.
i hope this has been of some help.
Sep 09, 2009 | Alesis RA-150 Amplifier
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
8 - 10 Amp - Airbag
Apr 02, 2009 | 2004 Dodge Intrepid
Amp cuts out after a while
My Alesis SA-300 started the cutting out when at moderate levels some months ago... Well, Radio Shack has instant gratificaion for those who have one in the neighborhood. Part number 275-249 will do the trick!
http://www.radioshack.com/product/index.jsp?productId=2062483
I replaced the Dong Woo part with the Radio Shack item and the amp is back to its old self... maybe even a little better. Loud, clean and steady.
Thanks to all you who have contributed to this thread.
Steve
Oct 17, 2007 | Alesis RA-150 Amplifier
Alesis RA-150 Amplifier Logo
382 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
