Question about Ricoh Aficio CL3500N Laser Printer
Printer problem when printing, there is a vertical white streak on the page so that words are not clear.
  • 4 Answers
Did you re-fill the black toner cartridge with genuine Ricoh toner or from somewhere else? It might be the wrong granularity.
Posted on Feb 09, 2008
  • 40 Answers
There's either something blocking the laser in that area, , there's a dirty spot on the charge or transfer corona (if it uses coronas), or something is caught on the wiper blade inside the drum cartridge. Your first step is to see if there is a corona cleaner that slides back and forth and make a test print. If you don't have that, or if that doesn't solve the problem, put the toner cartridge into another of the same printer and see if the problem follows; if it does, replace the cartridge. If it doesn't, look for something obstructing the laser path to the drum, either on the cartridge itself or inside the printer (possibly a label that came loose and is hanging down). If you don't have another printer, then replace the cartridge. If the problem goes away, you had a bad cartridge. If it doesn't, see the last paragraph. Let me know how it turns out!
Posted on May 29, 2007
Vertical white skreaks when printing
Check the remaining service life of the drums, also check the condition of your transfer belt. It is most likely your problem is one of those two elements.
Oct 07, 2014 | Lexmark C543DN Laser Printer
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have been having trouble printing my red. My letterhead contains a red "A" in it and a few other items have red. Normally, the red items have pink, yellow or white vertical streaks through...
Replace the magenta image unit. Yellow image unit also and for the white streaks have the glass that cover the laser cleaned.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2011 | Brother HL4040CDN Duplex Unit
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
There is a white vertical streak on pages I print.
You can pull out each cartridge and shake it gently to redistribute the toner. Try a half page test to eliminate the various stages of the image formation. The timing on this is not easy but through trial and error it can be helpful.
Jun 25, 2009 | Cannon MULTIPASS C530 Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
Minolta 2300DL Printer - black streaks
Hey Chuck, Any chance you can post a scan of one of the faulty pages ? This will make it easier to assess the fault. Print off about 10 pages of a page that is affected by the lines. Look at each page and see if you can detect a recurring pattern over any of the pages. If there is a pattern, chances are it is probably the PCU that is marked.
May 20, 2007 | Minolta magicolor 2300W Laser Printer
you will have to check the Minolta web tech support team for this one.
May 20, 2007 | Minolta QMS 2200DL Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
171 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
