Display goes blank at certain points during wash cycle
A real pain as at certain points of the wash cycle the display goes blank and stops for several mins and then when it restarts it goes back to the point where it stopped and repeats the process again i have changed the fuse as that's what it said it would be in the manual but that did nothing to remedy the situation
  • 15,935 Answers
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Water goes in it washes for little while then buzzer starts before wash cycle ends
Hi Gina,
When your machine stops during the cycle does it beep & hold some of the wash progress lights on?
This is how it displays where the fault is coming from.
The motor controller is the most common for this type of fault.
Thanks
Damien
Nov 07, 2015 | Fisher and Paykel Washing Machines
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Does Nothing During Spin Cycle than quits
You have a motor coupling gone.
Jan 25, 2009 | Washing Machines
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
Check pump fiter and pump.
Jul 22, 2008 | Zanussi ZJ1217 Front Load Washer
Spinning during all cycle
depending on how handy you are, replacement of the brake pads can be a real pain. As an experienced technician I specialized in Amana/Speed Queen for a while. I recommend you call a service man to replace the brakes. Its worth your while and your fingers.
Jun 04, 2007 | Amana NAV2330AW Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
