Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune OP code
This code is on the display and the door is shut and can not open. The washer will not start. How do I get it fixed?
I have the same problem....i fixed it once using the user manual so i know its in there...but i lost mine :(
Posted on Jan 09, 2009
I have an OP message on my Maytag washer FAV6800A/FAV9800A . The washer is not locked I can open the lead ...when I close the lid and start the washer the OP error comes up. Any help will be...
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "OP" error code. You have lost signaling thru the Left Hand Lid Lock............DH1200s
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
MY MAYTAG NEPTUNE MODEL FAV6800AWQ KEEPS DISPLAYING THE LETTERS OP
You have lost signaling thru the Left Hand lid Lock. The washer has not see the lid go closed thru the signaling with the magnetic reed relay in the Left Hand Lid Lock.
You could have a Lid Magnet out of position or severe corrosion. You can place a large magnet over the Left bumper like this and see if the OP error code clears;
See this post for troubleshooting the OP error code Left Hand Lid Lock Troubleshooting I go over OD error code troubleshooting but you troubleshoot the issue the same way for the OP error code.
If the Lid Magnet is not out of position you may have an open circuit thru the Magnetic Reed Relay as shown in the Pics of this link Left Hand Lid Lock Troubleshooting.
The p/n for the Left Hand Lid Lock is 25001048
Some other handy links. The Service Manual for reference. Sears Parts Direct for reference..........Rich
Jun 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune top load. I am getting an od code
Be sure to unplug the washer before attempting any troubleshooting. On the Maytag Neptune the "OP" code indicates a problem at the door switch. These washers have a common problem associated with this code. The door isn't completely waterproof and allows water to get into the area where the lid switch is, corroding the electrical contacts and wires. Use a putty knife or screwdriver to open the top of the machine to access the door locks. Look for any broken or corroded wiring connections and reseat and clean as necessary. Test the switch using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty switch. Sure hope this helped and best wishes.
Sep 10, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
Puy knife inserted at the outside cornes opens it up and you can play arround with them with you fingers try WD-40 to cur the sticky detergent residue and make sure they are connected. are you sure it didn't say OP?
Jan 16, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
