Question about HP Photosmart C5180 All-In-One InkJet Printer
Can't print custom paper size on HP Photosmart C6180
I've seen various solutions to this problem on here before but so far none have worked for me. I finally was able to print something on my 4.75 X 6.5 in. envelope (without getting an error message) by making a new custom paper form and setting both Word and the printer to this form, but the printer still thinks it's printing an 8.5 X 11 paper. Instead of printing the address in the middle of the envelope, it prints a piece of it on the bottom corner. Any thoughts on how to print it in the correct spot?
  • Anonymous Jan 19, 2009
    This printer is so frustrating!!!!! It won't print custom sized envelopes, even though they are a standard size. UGGGGGGG!!
  • 4 Answers
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Posted on Jan 09, 2009
The best solution is to change to Canon printer, in Canon you'll find a custom paper size option, you enter the size you need and print, i overprinted 800 xmas lottery ticket with my name and address 10 x 8 centimeters size without problem, with my office Photosmart c4400 printer i am not able to overprint an address in a 21.5 x 14 centimeters flier. Too much sophistication make impossible this simple work.
Posted on Aug 18, 2010
4 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: Custom Paper Sizes for HP Photosmart C3180
I have a 3100 series HP. On it you select "Properties", then the "Features" tab. On that tab, there is a "Resizing Options" menu item. It has a drop down menu with "Letter", "More...", and "Custom" choices. There you can define the size.
Posted on Oct 15, 2008
  • 4 Answers
SOURCE: Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Posted on Dec 18, 2008
  • 4 Answers
SOURCE: HP Photosmart 6150 AIO
Sounds like it might be the same problem I had on my HP C7180. It seems to be rampant throughout their Multifunction printers.
How to delete a custom paper size on an HPC6180
->Click the Settings tab.
->Click on Paper Size. A list of paper sizes will appear.
->Select the size you want.
->If none of the selections are suitable, select Custom. A box will appear inviting you to set your own measurements. Enter the width and length that you want.
->Click OK.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 20, 2012 | HP Photosmart C6180 All-In-One InkJet...
How can i overprint an 21.5 x 14 centimeters flier with my hp c4400? There is no way to configure the exact paper size and the size is not standard but i need to add an iformation to the flier.
Actually, we set the print size on the document using DTP application like Adobe Pagemaker, Microsoft word, Adobe Illustrator, etc...etc.. but if you've made the changes in the document and want to change the paper size from the printer's settings, you can try this. On the printing preferences, click the drop-down list of the paper size and select "custom", a new dialog box will open up, give a name to your custom size and select the size from the available lists. You can refer to the given pictures below:
and when the "custom" dialog box pops up:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 All-In-One and the paper is jamming ever time I try to print or receive a fax.
Check the specifications of the paper size and weight. It should be a supported paper size. Clen the rollers of the paper.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
Cannot adjust setting to print specific paper measurement
Your program should have a section in page setup to manage custom sizes. Enter this size. set size in your printer dialogue box and away you go! Inkypete
May 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot print envelope on HP Photomart C6180 All in One
What program are you using? If it's Microsoft Word, are you using the Mailings section, and envelopes?
Apr 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Mar 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 won't print borderless photos
Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
Want to print 2 wallet size on 4x6 photo paper
under print options it will pop up a menu saying to "only show options compatible with my computer...." unclick that and it will allow you to select letter size paper again
Dec 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
Dec 27, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
2,858 people viewed this question
Seeker5211
Seeker5211
