Question about Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
Can pre record programmes from the tv when I am out, I have also purchased the docking station.
Kind Regards
Roy
  • 8,596 Answers
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Posted on Jan 08, 2009
My Archos 605 WiFi will not always switch my NTL (Samsung) set top box on to make a scheduled recording.It will however change it to the correct channel if the box is left switched on and make the...
I have partly solved the problem by leaving the box switched on (any channel) then when the programme is about to record Archos 606 WiFi will switch the cable box to the correct channel and record. It will not however turn the box off after recording this has to be done manually using the remote handset.
In the instruction manual for the Archos docking station there is a footnote saying that in very rare cases the On/Off function does not always work and I am wondering if the Samsung (NTL) Box is one of them. I cannot get a direct answer from Archos support team on this issue when I have sent numerous E-mails. According to the manual I am working on the correct code number for the Samsung (NTL) box.
Feb 19, 2009 | Archos 605 WiFi Digital Media Player
No sound when I record from my TV
Are you using the DVR Station Gen 5 or DVR Travel Adapter?
Jan 23, 2008 | Archos 605 WiFi Digital Media Player
RCA cables and Home Movie Question
I have had my 605 for a week. The first thing I noticed is that all cables and connectors are special. No way to hook up standard RCA cabling to your TV. I have an AV 500 that is about three years old. Even the cables from it will not work with the 605. It seems that 605 was designed to cause us to buy additional equipment and add-ons. We can't even replace the battery, and its life is very poor; just over two hours!!
Also, I registered my product and got a password for their site. I have sent two questions to their service. Both time I was promised a reply in two days. I have heard nothing at all!! NOTHING! I am starting to wonder!!!
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 Dock station won't work with TV anymore
hi have you change the setting to component or rgb on the display settings
Dec 16, 2008 | Archos 605 WiFi Digital Media Player
For some reason my archos 605 wi-fi will not record from tv. Has been okay since I bought it some 4 months ago. Comes up with corrupted file or similar thanks Jim
Thank you very much for your e-mail.
I have been in the habit of just suspending my Archos between use. Problem was solved by simply turning the Archos off completely. On switch on, recording worked perfectly.
Thankyou for your help
Jim
Aug 05, 2008 | Audio Players & Recorders
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
Connecting to a tv
YOU NEED TO GO TO SETTINGS ANDCHANGE THE PLAY MODE TO PAL FORMAT
Feb 11, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 30 gb
Yes you can download music from the net
No you can't use it as a word processor (not yet anyway)
Widgets are not yet available - they are due any time now
Check you have the output from the cable box to the input on the docking station and the output from the docking station to the input on the TV. Double check all your connections. If in doubt, rip them all out and start over. Once connected you will have to set the TV to one of the Aux channels to see the content and ensure you hit the TV button on the Archos to push the output to the TV.
Oct 03, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
220 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
