Question about Compaq Presario M2000 Notebook
Bios chip failed
I have a Compaq Presario CQ50-107NR Notebook PC laptop. I tried updating the bios chip but before it could finish it lost power ( the battery died) and now it won't start. All i get from it is four beeps. no boot up screen nothing. what should i do?
    Genius:
  • 1,913 Answers
Open the back side ten remove battery.then refixit after clen dust from it.
if problem stilll then remove cmos cell for 15 minutes then it reset .
Posted on Jan 07, 2009
Compaq presario cq60 the caps lock blink constantly
You may try this fix. No guaranties though. Remove the battery and unplug power cable. Then hold down the "power" button for about 10 seconds. After that plug it back in and try turning it on. Again, this may NOT work but it has for others.
Sep 08, 2014 | Compaq Presario CQ60-220US PC Laptop
My Compaq Presario F500 running Vist Home Basic will no longer boot the operating system after I completed an advise BIOS update from HPs websit. I receive an error code stating that the system is cor
Hi.
Try this >>>>
Power down your Compaq Presario F500 notebook computer. Remove the unit's internal battery from its housing compartment.
Use a screwdriver to unscrew and remove all of the screws from the bottom panel of your Compaq Presario F500. Use your hands to lift off the bottom panel, revealing the inside of the notebook computer.
Look for the CMOS/BIOS chip: It will be located in the center of your computer's motherboard, which is itself located in the center of the case.
Remove the small battery from its housing compartment on the CMOS/BIOS chip. Then, press and hold the "Power" button on the laptop's case for a few seconds. This will completely discharge all electricity from the device.
Replace the CMOS/BIOS' battery. Place the bottom panel of the notebook computer back on and screw it back into place. Place the Compaq Presario F500's battery back into its housing compartment and press the "Power" button to turn it on. Your CMOS/BIOS will now be completely reset.
Good luck and please let me know how you get on!!!!
Regards.
Jan 29, 2013 | Computers & Internet
Shutdown
if it is in a no power no boot situation you will have to replace the bios chip or replace the motherboard. if you update the bios ALWAYS MAKE SURE YOU ARE ON AC POWER AND HAVE A FULL BATTERY. if your battery is weak make sure the power cord is plugged in and secure . if your computer looses power during a BIOS update it is bad .
Jul 06, 2010 | Compaq Presario R3000 Notebook
Changed out the motherboard reformatted a blank hardrive, No issues in the reformat.Installed drivers then updated the bios.Currently will only boot to bios briefly then shuts down.Tried resetting the bios...
Sounds like your BIOS update did not complete successfully. Head to the board manufacturers website and check if there is some way you can reload the BIOS and recover from this. Most boards now have dual bios which means that if one bios chip fails or an update fails, you can reload the stored BIOS through the other chip. If you are unable to recover from a failed BIOS update, you may need to purchase a replacement BIOS chip from the board manufacturer. You may even be able to reload the original BIOS onto the chip through your local PC repair store so give them a call and enquire..
May 21, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
Bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Jan 08, 2010 | HP Compaq Presario V2000 Notebook
Update bios on compaq presario m2000?
There are usually two ways with Compaq's
One is with a DOS boot floppy
The other is via a windows utility
both are usually available from the support section on the Compaq website.
Heads up only do this on mains power not battery !
DON'T stop it or switch off for ANY reason
If you knew how many crashed bios questions come through Fixya.
Check the text file or only as to what problems that bios fixes and if they don't apply to you then don't do it.
Most bios updates fix very minor issues nowadays
Sep 09, 2009 | Compaq Presario M2000 Notebook
HOW TO UPDATE BIOS
Go to this site: http://h10061.www1.hp.com/ccsearch/search?pname=Compaq+Presario+V3000Z+CTO+Notebook+PC&opname=Compaq+Presario+V3000Z+CTO+Notebook+PC&qry=BIOS+update&submit.x=0&submit.y=0&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=3180330&search=0 and update your BIOS if & only if you are facing any problems during normal operation, otherwise do not do so unless prompted to!!!!..sodeep
Mar 19, 2009 | HP Compaq Presario v3000z Notebook
Compaq presario v6000 laptop keyboard malfunction
Try reseting the BIOS to its defaults by following the instructions below :
Start or restart the Notebook and start tapping the F10 key immideatly you see the HP logo.
Now, in this press the F9 key to load the BIOS Default settings.
Press the F10 key to save the settings and exit the BIOS setup window.
Additionally, check by connecting any USB Keyboard to the Notebook if available.
Additionally, find the Product Number of the Notebook which is indicated with P/N printed on a white sticker pasted at the bottom of the notebook.
Open HP.com and enter this in the search field at the top right column.
Click on Software & Driver downloads and select the Operating System in the Notebook which should be Vista.
Scroll down to find BIOS under which you will find the BIOS Updates available for your Notebook.
Download and save the latest BIOS Update available.
Close all the windows and applications and double click on the file to update the BIOS.
Donot attempt to access any application or turn it off or restart when the BIOS is being updated as this will damage the BIOS Chip and make the Notebook useless.
The Notebook will restart automatically after the BIOS is Updated.
Hope this helps...
Jul 27, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario M2000 Notebook Logo
240 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
