Question about Lexmark X1240 All-In-One InkJet Printer
A designjet 700 with a black cartridge test on every print job
After test is through the printer displays service cartridge. This on every print job. If continue is pressed job prints
    Genius:
  • 1,913 Answers
Open the front door then pull the ink cartridge then cleat it from dust and ink then refix them.then try.
aslo check there is not any paper jam.
Posted on Jan 07, 2009
My hp office jet all in one printer is only displaying error ,when i turn it on
HP Officejet J4580 All-in-One Printer Troubleshooting ' HP ...
support.hp.com/us.../HP-Officejet...All-in-One-Printer.../troubleshooting/
Let HP find my products ... Note: This tool can only find HP products you are currently using or ... Error · Printer Problems after Upgrading to Windows 10 · A 'Paper Jam' Message Displays for HP Officejet J4500/J4600 All-in-One Printer Series ... PrinterSpecifications for HP Officejet J4500 and J4600 All-in-One Printer Series ...
A 'Paper Jam' Error Displays on the HP Officejet 4215 a
Dec 18, 2015 | HP Office Equipment & Supplies
Black ink cartridge is not registering as being in machine after changing
1.The carriage contacts are worn out and the contacts need to be replaced.
2.The Trailing cable is worn out and needs to be replaced.
It is highly recommend that you replace this both at the same time.
These are the two likely causes of the cartridge problems.
You can do it your self by following the service instructions at http://www.feedroller.com/store/Service%20Manual/DESIGNJET%20700,%20750C,%20750CT,%20755CM%20Service%20Manual.pdf
and you can get parts at http://www.donparts.com/products/53-DJ-700-750C-755CM/ for the plotter.
Jun 14, 2012 | HP DesignJet 755cm InkJet Printer
Film + error lights flash. I have replaced the ink
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
Sep 24, 2009 | HP DesignJet 330 InkJet Printer
Designjet 500 stops printing in the middle of print job
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP DesignJet 500 InkJet Printer
Print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
How can i print in just black ink
Interestingly enough the color cartridges are used for printing black on most printers. It helps make the black, um... well, blacker.
You can look on HP's website and see if they have a method of setting the print driver to only use the black ink.
Apr 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Our hp designjet 110plus is not printing black though the indicator shows we have black ink, what seems to be the problem? -Leh
Check whether the black cartridge is dry and whether it is releasing the ink properly.  This you can check by rubbing the paper on the place where the flows.
Else check with a new cartridge.  Even if the problem continues in the printer preferrence you have an option of service.  click on it and the problem will be fixed......!
Mar 13, 2009 | HP Designjet 110plus nr InkJet Printer
Plotter only printing in Cyan
Check your black cartridge. Do the pump the cartridge thing with the plunger on the left of the plotter. Check all the electrical connectors on the cariage and the cartridge - clean with water -or wd40 if you are very careful and check that all the contacts, about 40 of them are clean and undamaged on each cartridge. Replace with known working cartridges. run a color test as specified in the manual -- hp has relased the manual for this printer as they no longer service this unit.
Jun 23, 2008 | HP DesignJet 450c InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
