Question about Passport 9500i Radar/Laser Detector
My passport 9500i has no sound
My radar detector does not have any sound. the light comes on but not sounds
The little speaker in it is defective. Mine does the same thing and I discovered the defective speaker when I opened it.
It is now going to Escort to be reparied.
Posted on Feb 08, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Everything lights up and is working,but i have no sound
Do you accidentally have it muted? The Mute button, located on PASSPORT's top panel and SmartCord. Have you turned up the volume on it? Volume Control (VOL) To increase or decrease the audio volume, press and hold the (+) or (-) volume control buttons located on the top case. A sample alert tone will be generated, along with a corresponding bar-graph on the display. Once you have reached your desired volume level, simply release the button. This level will be stored in memory. In Preferences Auto Volume is the default. This feature will increase the audio alert level automatically when the ambient noise in the vehicle is high. Good luck.
Mar 06, 2011 | Passport 9500i Radar/Laser Detector
Looking for an online printable owners manual for an Escort 9500di Passport Radar/Laser Detector.
escortradar.com or 800 964 3138 they also have a pretty good tutorial about how detectors work and what the differences are for each different band go to the web side at the bottom of the home page click on ( radar school )
Apr 19, 2010 | Passport 9500i Radar/Laser Detector
My passport is not detecting the ka band as it used to what could it be?
police are wising up and updating their equipment. Alot of scanners are obsolete these days
Nov 18, 2009 | Passport 9500i Radar/Laser Detector
All the features on my 9500i work except the video display. I do not have the "dark mode"" enabled. Any thoughts on how to repair this problem? Thank you!
This likely is caused by a cold solder joint on the back side of the alphanumeric LED display. Escort will have to repair this for you.
Jul 19, 2009 | Passport 9500i Radar/Laser Detector
It doesn't sound
Your 9500i likely has a blown speaker. Contact Escort about sending in your RD to have its speaker replaced.
Jul 16, 2009 | Passport 9500i Radar/Laser Detector
Smart cord just flashes
Try the following. First, make sure if possible that the 9500i is powered off when you plug it into power. Then hold down the buttons (I forget which ones) needed to put it into USB mode and only release these buttons once "USB" is displayed after plugging it in again. Hopefully you will be able to get your 9500i to display "USB" again. If you can get it to display "USB", only then plug in its USB cable into your computer. Then run Detector Tools and see if you can re-flash the firmware.
Jun 24, 2009 | Passport 9500i Radar/Laser Detector
How do i replace a broken speaker in passport 9500i
The speaker is manufactured by PUI, but it is a custom OEM job for Escort. So you can't get it from any distributor or from PUI. In the late summer of 2007 Escort started installing a new "high temp" speaker. This new speaker looks just like the original speaker, but it is designed to be able to handle very high temperatures without blowing. If your 9500i is still in warranty, Escort will replace the speaker with the new "high temp" speaker, test and calibrate your 9500i, and install whatever their latest firmware is. If your 9500i is out-of-warranty, then you should call them and see if they will send you a replacement "high temp" speaker for a small charge. The speaker is easy to replace. A good while back I posted on radardetector.net detailed instructions on how to replace a 9500i speaker. It takes all of 10 minutes to do.
Mar 05, 2009 | Passport 9500i Radar/Laser Detector
Sir, I have a escord 9500i .Last few days there is no sound
If your 9500i is still in warranty, then Escort will replace the speaker with a new "high temp" speaker which won't blow due to extreme heat. If it is out of warranty, call Escort and see if they will send you a replacement speaker for a small fee. Search for instructions on replacing the speaker on radardetector.net.
Jan 19, 2009 | Passport 9500i Radar/Laser Detector
My Escort 9500i Passport is giving off TONS of wrong into...
That is not POP, which is a type of radar gun operating mode. Instead, what you are seeing are SWS (Safety Warning System) messages. Either look in your user manual or download the PDF user manual from Escort's web site in order to see how to turn SWS off.
Jan 06, 2009 | Passport 9500i Radar/Laser Detector
Passport 9500i Radar/Laser Detector Logo
574 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
