Question about Dell Precision T3400 375W 64bit (bwcw9z6_4) Intel Core2 Duo E4300 (1.80GHz/800MHz/2MB L2) 375W ... PC Desktop
WIRELESS CONNECTION Thanks for trying, but when I tried your solution the box read - wireless network connection: Not connected Linsys Wireless-G PCI Adapter. When I doubled clicked on this it said no wireless in range, make sure wireless switch on your coputer is on. Thanks anyway
  • 242 Answers
Check to see that your wireless antenae is on.. it is possible to turn on via your keyboard with a function key. this saves energy on the laptop. Look at your keyboard and see if you see a function key on one of your keys that is activated by teh FNC key.
Stan Skaggs
Posted on Nov 24, 2009
Describe your Linksys 2.4 GHz 802.11b Wireless - B PCI Adapter Problem where is the network key locaded
The network key is actually programmed into the wireless access point you are trying to connect to. You need you provide your network connection with that code in order for the adapter to get permission to connect to the router.
Unless you are connecting to an unsecured connection - then you don't need a key at all.
Jan 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
About a week ago my HP Pavilion DV4000 couldn't pick up my wireless linsys G router and said that no wireless connections were found. I had to use a wireless B card I had lying around but still having...
You are using a B wireless adater on windows XP computer.
Tere might be adapter utility installed on your computer. You can use that software to connect to the wireless network or you can switch over to windows software to connect.
It will be better if you use the WINDOWS XP to connect to the network.
Check the wireless settings of the router also.
Click here for more information
May 03, 2010 | Linksys Wireless-G WRT54G Router
I was trying to make my wireless connection work quicker using my hotel connection but now it's not even connecting to it. How I can reset those options back to their default values. I'm using a Dell...
Click on start, go to control panel, double click on network and sharing center, on left click on manage wireless networks, right click on wireless network connection and click on properties. At the top click on wireless tab, check the box which says “use windows utility to connect wirelessly” then click ok. Right click on wireless network connection and click on view available wireless networks. Select your network name and click connect. If asked, enter the wireless password and you will be connected.
Feb 25, 2010 | Computers & Internet
Intel Pro wireless modem won't connect to my wireless router
Check whether the drivers for the motherboard is installed for the wireless Adapter card if it is onboard or if it is a PCI wireless card please reinstall the drivers using the software which came with that card. Thanks. It should work.
Jul 29, 2009 | Intel PRO/Wireless 3945ABG Network...
Wireless connection
welcome to
yes offcourse ur dell inspiron 5100 laptop support wireless connection,and it will detect the wireless connection in ur computer,uninstall and reinstall the wireless driver and then try and connect to wireless connection,and what u can do is that reset the router and then try and connect to wireless network it will definately connect..and it will also detect the wireless signal also........good luck
pls rate this solution its a request..pls
Feb 11, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Belkin wireless G adapter shows as working but no networks
make sure the Wireless zero configuration or WLAN auto configuration service on your OS is running
Try to search for wireless network using the Belkin wireless utility after disabling windows
Nov 19, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
MSI wireless 802.11 LAN network connection not connecting
i don't know how should i connect to the internet with wireless in msi cr400 laptop!
May 05, 2008 | MSI : MP54G Wiress 802.11g Mini PCI Card...
Dell Precision T3400 375W 64bit (bwcw9z6_4) Intel Core2 Duo E4300 (1.80GHz/800MHz/2MB L2) 375W ... PC Desktop Logo
106 people viewed this question
Alun Cox
