Question about Dell Inspiron 1501 Notebook
Dell inspiron 1501 will not charge
My wife purchased a Dell 1501 18mths ago and now the Dell does not recongnise the original battery supplied by dell and even when it did it would not charge past 3% rendering this laptop a desktop! It would appear from your site there are issues with the Dell batteries but this is the original one supplied and I didn't really want to spend £45 on a new battery that will probably break soon away. HELP.....Do you have any ideas or solutions.
Many thanks, Charles
  • dino_daniel2 May 06, 2009
    Computer will not recognize the battery. It also says it will not charge it. My battery has 63% of life. Does anyone have the answer?
  • Dan rogers
    Dan rogers May 11, 2010
    Did you try to contact dell and see if they would replace the battery when it was or if it still is inder warranty?
    Genius:
  • 1,913 Answers
Open thebattery and refix it after clear dust from its slots.
also change adapter of same output.
if still problems then u have to purchase new battery.
Posted on Jan 07, 2009
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Feb 13, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 new battery purchased in September and now won't hold a charge
The battery should be protected if you purchased it from Dell or a reseller offering warranty. You should compare all information on both batteries to ensure you have the right one. Just because it fits does not always mean it is the proper battery.
Dec 30, 2009 | Dell Inspiron 1501 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
DELL XPS 1210 i purchased a replacement battery not recognised
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Jan 29, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell inspiron 6000 not charging
I have a Dell Inspiron 6000, and so does my wife. One day coming back from the airport, the power adapter cord(the end that plugs into the laptop) was hanging out the door and was dragging on the ground. Well the end was unusable and I was out looking for another AC adapter. Dell wanted $80 for a new one, but I found one on ebay for $40. But once I got it, I found that it would power my laptop, but wouldn't charge my battery. I thought, I know the old one works, so I cut the end off the ebay one and wired it onto the original one but ended up with the same result. Called the ebay seller and turns out these AC adapters are dell seconds. They claimed to test them and offered to send me another one and did so. By that time the new one from dell dropped to about $40 so I just bought it too anyways. The new dell one worked and the second one from the ebay seller did the same as the first one he sent me. I found out that the dell laptop wont charge the battery if the supply goes below 19.5V. By me hacking the other end on the original AC adapter, didn't result in the best insulated connection from the other wires. Also, if anyone know anything about AC adapters, is that they have a "Step Down Transformer," and the company that makes them, low balls the windings so that if they are off on the voltage, they are under, and not over, thus not frying the more expensive laptop. My suggestion to you is to just pick up a new AC adapter from dell. Also, the rubber coating on the cord is pretty soft and splits easily.
Sep 12, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
205 people viewed this question
Alun Cox
