Question about Epson Stylus Photo R300 InkJet Printer
Power will not come on
I've had this printer for a few years, it's a good printer i'm not ready to throw it out if it's something simple. i realize it's old but it was working great up til now. when i try to power it up the 2 lights below basic and advanced come on but then they go right off and nothing else happens
    Genius:
  • 1,913 Answers
Refix power cable again. or to change power cable.
Posted on Jan 07, 2009
I just bought a 2003 Envoy It had the check engine light on. It showed on the the scanner a code for the Crankshaft Sensor and said something about advanced timing. So i've had the crankshaft sen
Why would you be at a dealer with a 10 year old vehicle
Have extra money to throw away
How about a local repair shop
How is it you had work done & still
have any problems,what do these
shops do,half a job
Mar 18, 2013 | 2003 GMC Envoy
Error message "Refer to Printer Documentation 0-61011bed
My experience is that you need to leave the unit disconnected from the mains completely for longer than the other solutions suggest. Leave it overnight, disconnected from its power supply and with the power supply disconnected from the mains. This has worked for me twice. The first time I thought I had fixed it with something else. That did not work the second time and I realised it was something else I had done - leave it disconnected overnight (about to throw it away) before giving it one last try. I suspect that something needs to thoroughly discharge. Anyway, it is a simple solution to try. Best of luck! :-)
Nov 18, 2011 | Office Equipment & Supplies
Have f11 fault tried to reset and machine starts up, turns a few times, then gives a strange noise then f11 appears and pump starts draining, had f11 few years back and was fuse but remember at this time...
sounds like you've either got a stiff motor or gunk in the drum making it difficult for the motor to turn. When the fuse blows the drum won't turn at all but as yours is trying to turn then throwing the fault up it sounds like something is causing too much resistance
Aug 26, 2011 | Dyson Flowcheck CRO1 Front Load Washer
I have a panasonic tv that is a few years old.
youre tv has a loose cantact inside .its just a simple re solder.
Jan 25, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Last night I installed a new XEROX maintenance kit in my Phaser 8500(NOT "DN") and I had a problem I've never had in 3 or 4 years I"ve owned this printer. It was kind of hard to pull the old one out, and...
Hi.
Standing at your description, you have installed the new kit in the proper way. Unless you broke some plastic part (you would have realized), it is rather unlikely that there is damage inside the printer.
If you find toner pebbles inside the printer , then the printer must be cleaned internally. That is probably causing all the troubles.
Residual toner can cause more faults, some of them (eg. drum thermistor) can only be fixed by a technician.
Here broad lines on how to clean a laser internally. Instructions are for a B&W, but steps are more or less same on a color printer.
Clean your laser printer safely with these tips
How to Clean a Color Laser Printer
Regards.
Nov 14, 2009 | Xerox Phaser 8500/DN Printer
HP 2510 printer in "wait" mode indefinitely
It sounds to me like the printer needs repaired/replaced as the gears which drive the printer cartridges' belt are no longer aligning correctly. At today's prices, I strongly suggest just replacing the printer as you can get a new one pretty cheap now. Good luck!
Apr 18, 2009 | Office Equipment & Supplies
Lexmark 2500-Constantly runs out of ink whether I
I take it that the ink is not leaking out and running all over the place?
A cartridge should print maybe 500 or more pages (I can't recall just when I looked this up, but the number popped into my head). Sounds like you are getting less than that.
If it's not leaking, then the ink shouldn't run out if you are not using the printer.
The only thing I can tell you is that you have a bad printer. In my opinion, Lexmark consumer products are not very good--but that is only my opinion (and the opinion of many of my associates).
Sorry I can't give you really good news.
Mar 23, 2009 | Lexmark X2500 All-In-One Printer
'communication error' and won't turn off
From my experience, FW and Epson printers don't always work well together.
Switch it to USB then delete and re-add the printer in the PRINTER SETUP UTILITY, and you should be okay
May 21, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
