Question about Samsung HT-WX70 Theater System
No Surround Sound in Aux 2 mode
I hooked up all speakers directly to the HT-WX70. (I am not using the wireless speaker box as the speakers are directly in the unit). When watching a DVD using the unit, the surround sound is excellent. However, trying to watch directv or the PS3, there is no surround sound. What am I doing wrong??
Thank you in advance...
    New Friend:
  • 111 Answers
Genarally tv output contain two signals.(steereo).it dosent have surrund output.thats y its not hearing surround sound from your system.
Posted on Jan 08, 2009
User manual
You get surround sound only if you hook up your Optical out from your TV to the Optical IN on the HT-H4500 using an optical audio cable. You may have to buy such a cable if one was not included with the TV or the home theater.
Follow the link below and click on the Manual tab.
Samsung Home Theater System HT H4500 Home Audio
Oct 04, 2014 | Samsung HT-H4500ZA Home Theater System 5.1...
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
How to I get my surround sound speakers to work with the cable box?
One way would be to connect one of the the digital audio outputs to the HT as an input (HDMI or optical digital audio).
Another would be to select one of the DSP modes that uses surround speakers. They work with all input modes.
http://downloadcenter.samsung.com/content/UM/200802/20080203110035031_HT-Z510-XAA-0125.pdf
Jan 28, 2011 | Samsung HT-TZ512T Theater System with...
Back surround speakers dont work.
If the display reads 2 chan then that means stereo, and the sound mode is not in any type of surround processing. For your surround speakers to operate you must select a surround sound mode.
Dec 06, 2009 | Audio Players & Recorders
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
Surround sound
your tv might have aux out on the back, I would use that first.
IF NOT, then you will need to use the cable box.  Insert the red and white plugs at the other end of  this cable into the AUDIO IN TV or cable box connectors on the
media center.
Be sure to match red to red and white to white.
3. Use your TV remote control to turn the TV speakers
down to minimum volume.
This prevents the echo effect of audio playing
through both the TV speakers and your 3•2•1®
system speakers.
Apr 09, 2009 | Bose Cinemate Digital Home Theater System...
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Surround Sound Speakers and AUX
You have the mode selector for the surround sound on the wrong switch setting. Look at the owners manual to see what setting you need for synthensized suround. Go to http://www.samsung.com if you need an owners manual. You will find it with a little bit of searching. Good Luck
Oct 08, 2006 | Samsung HT-P38 System
Samsung HT-WX70 Theater System Logo
332 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
