Question about Lexmark X2350 All-In-One InkJet Printer
Paper feed problem
When the paper feeder pulls the paper down inside the printer to print, the paper would go in on an angle and just keep rolling and then jams up. We can print up a 4 X 6 picture but anything bigger just does not go through.
Wendy
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Paper wont feed
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X5650 AllInOne InkJet Printer
Lexmark x6650 won't take paper correctly
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
Jan 23, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Paper wont feed
Jan 09, 2012 | Lexmark X Office Equipment & Supplies
Lexmark printer wont print
Jan 04, 2012 | Lexmark X4650 All-In-One InkJet Printer
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
When the printer takes the paper it pulls it down on an angle
There could be something that's blocking the paper path.
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
Jul 24, 2011 | Lexmark X3350 All-In-One InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    The printer keeps telling me it's out of paper, which it isn't
    1> Open the sheet feeder cover and pull out the paper support.
    Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
    Pinch and slide the paper guide to the paper's left side.
    Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
    Pull down the paper output tray supporting with both hands.
    Pull out the extension completely.
    Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
    Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
    If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
    Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
    Reply to question
    It sounds like it may be a part of your paper feeder. Hope it is under warranty. The fact that the printer only started to grind and bang when it appeared to feed the paper at an odd angle points to this to but... Is the part the same colour as the inner printer workings you can see down where the paper loads. Do you have a 2 year old in the house as they like to feed things down holes!!! It may have been a foreign part from another toy!!! Believe me this happened to a friend of mine. They had to replace the paper feeder.
    Feb 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
    Lexmark X2350 All-In-One InkJet Printer Logo
    139 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
