Question about Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 my printer will not respond
every time i try to print my computer says "problem communicating with the printer". i have got new ink and a new usb lead.
    Genius:
  • 1,913 Answers
My Lexmark X1270 printer at one time worked, everything was good, then when I put a new color to black will not print any other color or a black color, print only a little pale, almost do not see anything...
Lexmark products work best with genuine supplies. Lexmark does not recommend the use of refilled, remanufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
You can try to clean your cartridge nozzles using the Lexmark software on your computer. From your computer, go to Start menu > Programs > Lexmark X1200 Series folder > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
If that does not help, maybe it would be best to replace your supplies with genuine cartridges.
I hope this helps.
Dec 02, 2011 | Lexmark X1270 All-In-One InkJet Printer
I just purchased a new black ink cartridge for my printer and it is not printer. The printer stop printing. I have a Lexmark X1270
Try to re-seat your cartridges into the printer.
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. Close the printer cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, re-insert your color cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, open the printer cover and reinsert the black cartridge. Close the cover and check for errors.
  7. If error appears when black is inserted, try to insert a different known working cartridge (your old cartridge maybe) to determine if it's a faulty cartridge issue.
If you can make a copy using the Copy button on the printer operator panel without a problem, then it could be a communication problem between your printer and the computer. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply reboot your pc and unplug and re-plug the printer into the power source to reset it. When everything is back on, try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X1270 on/off light keeps flashing. was working correctly, until i changed the ink cartridges, then i couldn't get the computer to communicate with printer to tel the printer that new/old ink....
One card is not recognized. Try to remove, clean contacts on the cartridge and the printer and then put them back.
Check if you use the correct cartridges and you put in place.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 10, 2011 | Lexmark X1270 All-In-One InkJet Printer
Not printing.
trying to photocopy paper / buttons not working coming out blank
Mar 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 Not printing.
Did you put the right numbers of the cartridges?
Sep 30, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 not printing in color
Is the cartridge a Lexmark cartridge or a refilled cartridge?
Remove the cartridge from the printer, take a damp paper towell and wipe the cartridge in one direction on the bottom. Is Ink coming out? If yes then put the cartridge back in the printer and try to print again. If the answer is no and the cartridge is brand new you need to return it to you point of sale and get a new one as its a bad cartridge.
If the cartridge is a refilled cartridge that is probably the problem. Lexmark printers do not support refilled cartridges.
Thanks
Catherine
Sep 08, 2008 | Lexmark X1270 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
