Question about Fossil VT2654 Pocketwatch
To replace battery of pocket watch
I want to replace the battery of my pocket watch but I cannot find the niche to prise the back open to replace it. Would you know where the slot is?
  • 4 more comments
  • Anonymous Nov 12, 2007
    I have an old Waltham pocket watch, and I don't know how to get it open. It has a hinge in the back aligned with the 6, and a little niche above it. I tried to pry it open there without any success.
  • Anonymous Apr 01, 2008
    Same thing here. I wanna be able to walk around the street with my grandapa's pocketwatch, so help me!
  • Anonymous Jun 12, 2008
    I canno0t get the batter that is on the inside in
  • Alice May 03, 2017
    I have a remington pocket watch from my great great grandfather and I don't know what battery it takes can you please help me.
  • Ronald
    Ronald May 05, 2017
    ALICE - More than likely your watch, if from 2 generations back, never ran on a battery. It's a wind-up watch; simply wind it with the stem you use to set the time with. For winding, the stem needs to be all the way in/down; for setting the time, pull it up and turn it. Should run for a day or two before re-winding.
  • Ronald
    Ronald May 05, 2017
    For battery operated pocket watches(assuming it has not been opened before), the tiny slot/notch or pry-point for removing the back is located just below the stem. Hard to see but responds to prying gently with a small utility knife blade. When reinstalling the back, locate the notch in the same place - below the stem, for the next time the battery needs changed.
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
Posted on Nov 20, 2008
I need to get the back off my new ice watch to replace battery but I can't? Anyone know how please?
Waterproof or water resistant watches usually need a wrench to unscrew the back. I use a pair of 90 degree circlip pliers. A jeweller would remove the strap and fit the watch into a holder before using the wrench.
Few jewellers would guarantee the water resistance of a watch after fitting a new battery. If it is required a watch be returned to its original specification it must be returned to the manufacturer or an agent for battery fitting and pressure testing.
Some watches have a back that is pressed into place. Fairly easy to prise off but very difficult to replace without the tools. This type does not have the grooves a wrench fits into.
Apr 10, 2016 | Ice Watch Watches
Need battery replacement. Who does & rough cost?
A battery for a watch?
There's a few standard sizes. A battery takes 2 minutes to replace. Any jewellers shop would do it for you - or a market stall .. or really, anywhere that sells batteries.
You can prise the back off your watch and remove the battery yourself. I bet you wouldn't pay more than 5 dollars for a new battery
Mar 07, 2016 | Watches
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
How do I replace the battery in my FS4389 watch?
IF YOU TURN YOUR WATCH OVER YOU WILL SEE A GROOVE . IF YOU FIX A PIN UNDER IT .IT WILL PRISE OPEN AND YOU WILL BE ABLE TO GET ANOTEHR BATTERY YOU SHOULD BE ABLE TO PICK THEM UP IN TOWN CHEAP WITH-OUT GOING TO A JEWELLARY SHOP ,HOPE THIS HELPS
Jan 28, 2011 | Fossil ES2519 Watch
I need to know how to replace the battery in my fossil watch. how do i get the back off to check the battery
IF YOU LOOK AT THE BACK THERE SHOULD BE A GROOVE IF YOU GET A PIN IN IT IT SHOULD PRISE OPEN OR A SMALL JEWELLERYS SCREW DRIVER
Jan 28, 2011 | Fossil Blue watch #AM3423 Watch for Men
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Oct 04, 2010 | Colibri PWS-95877-N Pocket Watch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    Opening back of watch for battery replacement
    Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
    Mar 01, 2008 | Watches
    Fossil VT2654 Pocketwatch Logo
    5,729 people viewed this question
    Top Fossil Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Ray Murphy
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
