BENQ TFT monitor T905 doesn't work
I have a BENQ TFT monitor T905 from a few years. Yesterday I turn on the monitor but It does't work. When I turn on the monitor the LED is green for a while (but doesn't appear the welcome message), after some seconds the LED turns yellow. If I turn on the PC the LED turns green again and maintain this state.
First of all I need help to open the monitor.
Thankyou in advance
4 Suggested Answers
dragon_sun25
  • 107 Answers
SOURCE: benq t905 monitor blank
Fist check the fuse on the inverter board if it is blown replace it if not you need another inverter board as it has fried. But I looked and was unable to find a new/replacement inverter online so I wish you the best of luck
Posted on Dec 08, 2008
budmrtn
  • 11361 Answers
SOURCE: Benq T905 Monitor's green light turns on and then
Check for blown MOSFET IRFU9024N and transistors C5707/5706, and fuse in the inverter circuits section. Also look for bad caps with bulging top/seal. See some pictures of failed Dell monitors (BenQ made alot of monitors for Dell), http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 14, 2010
  • 112 Answers
SOURCE: model is BENQ T905, AFTER
Make sure cable to the computer is properly connected and also your PC is in normal condition.
Posted on Aug 06, 2011
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
Model is BENQ T905, AFTER SWITCHING MONITOR ON, IT SAYS ' NO SIGNAL DETECTED ! ' AND GOES ON TO STANDBY
Aug 06, 2011 | BenQ T905 (Black, Silver) 19 inch LCD...
I received a benq t905 from my parents the other day and i just hooked it up to my computer and it won't work. everytime i press the on button it blinks green and makes a quiet beeping noise and then...
On rereading that post, I note that it shut itself off; perhaps it is time to open it up and fix it (if you're up on your electronics safety) per the _stinks_ note, below; you get to resolder some stuff running the backlight and replace a couple of standard capacitors and transistors, from what I can tell.
Things sound sort of normal for a driver being finicky about DVI modes; did the monitor driver not install, or just not bring visible results? You set your OS to 1280x1024 having booted to VESA (safe mode,) right? Normally when the resolution/sync is out of range, the status light is green constantly and you get a little note; maybe it's just too far out of the 56-76Hz video rate for that.
It's also possible that your backlight is failing (they fail short, as in too few ohms) or the monitor settings are set incompatibly...DMI or VGA cable? Does it stink?
Jul 25, 2011 | BenQ T905 (Black, Silver) 19 inch LCD...
Can not see picture very dark
You may want to read this:
http://www.badcaps.net/forum/showthread.php?t=6053
And also look at failed Dell monitors (made by BenQ)
Please post back what you find.
Apr 24, 2010 | BenQ T905 19" LCD Monitor
Benq T905 Monitor's green light turns on and then off
Mar 14, 2010 | BenQ T905 (Black, Silver) 19 inch LCD...
Popping up of ''Auto adjusting'' on 15'' TFT BENQ monitor
Check the cable connections from the computer to the monitor, you might have a loose cable or bad connection.
Otherwise: did you upgrade your graphics driver lately ? And when do you get these popups, always or only when (i.e.) watching video ?
Aug 15, 2009 | BenQ Computers & Internet
Benq t905 monitor blank
Dec 08, 2008 | BenQ T905 19" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
