There are a couple reasons that the B70 might stop in the middle of brewing so one cannot be certain. The first one is where there are calcium carbonate deposits on the heating element and as the water in the boiler is agitated during pumping there is inadequate heating from the heating element and the thermostat shuts the brewing off when cooler water rises to the thermostat. Try running a mixture of 50/50 white vinegar through the unit a couple timesxto dissolve the calcium deposits or descale the unit per Keurig instructions. Secondly, it could be a faulty thermostat. If you are not handy, mechanically oriented I suggest buying a new one is best, least expensive. I believe that keurig coffee makers are able to brew 5000 cups without a problem. However our experience is that units with more than 5000 brews are prone to leakage, electricalr problems.
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
I have the TCM700 and it would turn off before the brew completed. This was because it had some sort of buildup from use. The manual recommended to brew with white vinager and water. The exact mix was in the manual, but my wife just did all vinager. Worked great.
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Bad temperature sensor, possibly. Unless you are good with electronics repair it's probably not worth paying someone to fix this. Buy a new one at wal-mart.
