Question about EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer
The washer is leaking water from the back, at the bottom of the washer where the drum and the back interlock
Water runs out of bottom of drum through machine onto floor
The first thing to check is the bellows, also called the front seal. Look for any tears, if any found, that would be your problem. If not, then the next thing is to take the top off the machine by removing the screws in the back of the upper part of the machine and checking the lines that run from the water valve to the dispenser.
May 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF MY WASHER,IS THIS SOMETHING MAJOR?
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly is it leaking, inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. to replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps...
Daniel
Aug 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
pump could be bad, hose could have come off, seal on bottom of drum things to ck
Apr 10, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool washer machine
I suggest you remove the front of the washer and observe the base of the drum and all hoses while in operation, using a flashlight attempt to find the source of the leak. **USE CAUTION!** Moving parts, water and electrical components present a very real hazard! If you have a top loading washer which agitates the clothing back and forth, one possible cause is the transmission. There is an internal locking mechanism which sometimes fails and will not engage, allowing the drum to continue to spin in one direction. The water will rise as the drum gains speed until it reaches the overflow outlets at the upper portion of the drum. These overflow outlets allow the water to spill out inside the bottom of the washer and out onto the floor. To check this, run the washer with the lid open (to do so, use a plastic or dry wooden stick [something non-conductive] to push down and hold the safety interlock switch closed) if the washer does not agitate back and forth and only spins in one direction you have a transmission problem. JUST BE CAREFUL WHEN OPERATING WITH THE INTERLOCK BYPASSED AS YOU WILL HAVE EXPOSED MOVING PARTS! If you feel any hesitation or concern about doing this...STOP!!, get someone comfortable or certified to do this type of work. While it is not difficult to do these things, there are risks and a momentary distraction can be painful, disfiguring or deadly. In this case, a repairman can be cheaper than a trip to the emergency room. You be the judge of your own skills and abilities.
Good Luck
Jan 30, 2008 | Washing Machines
EuroTech EWF272 Extra Large Front Load All-in-One Washer / Dryer Logo
21 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Electrolux
Electrolux
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
