Question about Panasonic Lumix DMC-FZ28 Digital Camera
Connecting my cam panasonic fz28 to my pc
I have a panasonic fz28. iam using a sandisk 8gb sdhc card. now iam not able to sync my cam with my pc even with all the softwares being installed. it shows the access symbol when connected with the access word written in red colour. and most importantly once connected my camera hangs up and i have to remove and replace my battery to bring it back to normal state. i also experience electrical shocks on my camera when conected to my pc. please give me a solution for this....
  • Anonymous Jan 12, 2009
    I have the same problem on my Windows XP PC, but on my daughters Vista Laptop, all works OK??
  • Anonymous Jan 27, 2009
    Having the same problem, except for the electrical shocks...
To solve this problem, I bought an SD card reader.
All you have to do is plug your SDHC card into the reader, then plug the reader into your USB port, and you should be able to access your images/videos.
I have the same 8Gb SDHC 15 MB/s plus the same camera (FZ28) and it works perfect for me. - Doing it this way is much easier.
You can find SD card readers (Which will work also for SDHC cards) on ebay for a small price of around 2-3 pounds (£) at cheapest. - Just type in "SD Card Reader".
Hope this helps.
Posted on Feb 02, 2009
Need information on micro SD HC, and how do i format for my panasonic dmc-fz28
Hi
The Panasonic Lumix DMC-FZ28 uses SD and SDHC cards. If you have a microSDHC card you will need an adaptor to make it into a full size card. This may have come with the microSDHC card. The card can be formatted in the camera. If you have problems formatting it in the camera you may have to format it in a computer or USB reader first, and then place it in the camera to format it
Jun 17, 2012 | Panasonic Cameras
Panasonic Lumix ZS7. Getting error "Pictures will
The mode dial on the top of the camera is set to clipboard. Turn the dial to P or iA.
Jan 10, 2011 | Panasonic Cameras
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Is lumix dmc-fx33 compatible with sandisk ultraII 8gb sdhc cards?
No, 8 GB is too large. According to page 5 of the manual, 4 GB is maximum:
•When the term card is used in these
operating instructions this refers to the
following types of Memory Cards.
– SD Memory Card (8 MB to 2 GB)
– SDHC Memory Card (4 GB)
–MultiMediaCard (still pictures only)
More specific information about memory
cards that can be used with this unit.
• You can only use an SDHC Memory Card
if using cards with 4 GB or more capacity.
• A 4 GB Memory Card without an SDHC
logo is not based on the SD Standard and
will not work in this product.
The manual can be had below:
http://service.us.panasonic.com/OPERMANPDF/DMCFX33.pdf
Oct 05, 2009 | Cameras
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
SanDisk 8GB SDHC card cannot be read by either computer or T-Mobile Dash phone.
Solution :
Put the card in your phone, link the phone to your pc and format the card through your pc. You should see two additional drives, one for your phones memory and one for your card. I had the same problem with my phone but it is now sorted !
Paul
Oct 11, 2008 | SanDisk 8GB microSDHC Memory Card with...
Panasonic Lumix DMC-FZ28 Digital Camera Logo
204 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
