Question about Canon LC-3175 Laser Fax
Print function isnt working
Im having printing problems with my Canon LC-3175ms. Im able to use the fax and Im able to copy but when I try to print- it acts like its gonna print but nothing happens. The job light lits up but nothing comes out. When I 1st installed the driver, I was able to do a test page but now its not working. I installed the driver again but its still not printing. Can you please help asap?? Thanks a lot
  • 328 Answers
What a tank! Great machine. I have never tried to connect to a computer. What op system are you using? Windows Vista and maybe XP may not support this model. Look for undates. What cable are you using? I just checked with Canon and found this unit is supported by Win 95/98. A firmware update from Canon may solve it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 10, 2007
SOURCE:
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Hello - We have a Canon Model 3175MS Fax Machine - we want to print a comfirmation that a Fax has been sent. Is this possible? Thanks! Marcy
Yes, it is called a `transmission report' (TX report), and is a setup option.
You can change this setting with the following procedure:
Open the 1-touch panel to access the function keys.
Press the `data registration' key to access the user menu.
You should see `user settings'. Press the `set' key. Press the cursor down key to get to `report settings', and press the `set' key. You should see `TX report'. Press the `set' key. Cursor down till you see `output yes'. Press the set key.
Press the `stop' key to return to the normal screen.
It is now set to print a report after each transmission.
Oct 07, 2010 | Canon LC-3175 Laser Fax
How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Jul 22, 2010 | Canon LaserClass 9000L Plain Paper Fax
Unable to do fax can print but unable fax
Canon PIXMA MP250 series serves with PRINT + SCAN + COPY function. No FAX function
Jun 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Faxes in memory & will not print out
Unplug the power cord for 10 seconds
Nov 11, 2008 | Canon LC-3175 Laser Fax
"waiting for report" /won't copy
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
Apr 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing on Imagerunner 210s
depends on which additional function you are trying to do.
You have it as a copier only right now, you can add
duplexer for two sided copies
network for your computer to fax and print and scan
document feeder to put copies on top and feed automatically
There are a lot of options you need to decide which function you are willing to pay for.
Good luck
Dec 04, 2007 | Canon imageRUNNER 210S Copier
Canon LC-3175 Laser Fax Logo
77 people viewed this question
Clive
Clive
old marine
old marine
