Question about Lexmark E232 Laser Printer
When printing large documents , it goes on pause after two pages
- and then, when I click 'resume printing', it reprints the same two pages, and then the pause button comes back on.
I get this problem printing pdf files and Finale documents. As I'm a composer and often need to print 90-page two-sided documents, this is a real problem.
The pause light comes on prematurely often even when I'm just printing on one side of the page
I have a new iMac, now at 10.5, but the printer has been behaving splendidly until quite recently.
  • john_plant Jan 12, 2009
    Thank you very much.
    I'm sure that's the solution - but I tried sanding
    the rollers, and now either the paper jams, or the printer indicates that I'm out of paper. I guess those rollers have done their time. I hope it's easy to find replacements. Thanks.
  • 1,031 Answers
  • Have you tried with a different computer altogether?
  • When you tried updating the drivers and all, did you first uninstall the printer, and uninstall the print driver from the print server settings in Windows?
  • Did you clean it with alcohol? Is that why squeaky clean?
  • Is a certain print job freezing up each time? then Possibly a really large document being sent to print spooler that is in turn seemingly freezing everything up
  • What application are you printing from when the problem occurs? mostly large pdf print file , can frozen up the print spool by trying to print a somewhat sizeable PDF document from Adobe Acrobat. Adobe Reader has caused some issues like that in the past. Sure enough, dont try to print long PDF files from within Reader, youll have no other issues.
hope this helps.
Posted on Jan 10, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 10, 2009
    when a job is accepted into queue, it will auto-pause if over the size restriction. .
    The printer might not have enough memory to print large documents. If this is the case, increase the available virtual memory,
    Brigadier General:
  • 5,158 Answers
First.. ensure you have the latest driver for that printer here
http://downloads.lexmark.com/perl/downloads/downloads.cgi
    Sergeant:
  • 378 Answers
Just relad the printerdrivers in the syatem again after uninstallig it.as when you will reinstall the printer all the new settings will be set in the system automatically.and it will work as normal.
  • Lexmark Master
  • 19,396 Answers
You need to empty the printer cue.
  • Ginko
    Ginko Jan 10, 2009
    You need to empty the printer cue, that is the reason why the printer is printing same documents times and times again.
    Unplug printer usb, and unplug printer power cable, then restart computer, and access the printer cue to clean it.
    To get to printer cue you go to control panel>>installed printers>>then double click on your printer.
    There you will find the list of documents in cue, select all and chose purge printer cue.
    Reconnect the printer back when finished.
    Sergeant:
    Novelist:
  • 326 Answers
. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Printer reprinting the allready printed pages
Make sure that your document that u r printing's page size is set to A4!Good luck!
Apr 05, 2010 | Canon Office Equipment & Supplies
Printer keeps on feeding paper and prints illegible material -- if I turn off and on again it will continue feeding same --- how can I correct this problem which has occurred before and stops and resumes...
I assume you use windows XP and have you printer connected to you computer directly.
First turn off the printer, then go in your printers manager and pause the printer you have problem with it.
Delete all documents still in the printers queue. When deleted, put back on the printer, unpause the printer and print a test page (with the printer's property page on, you should have a test page button), if they dont delete, restart the computer, they shoul not be ther after rebooting.
If the test page goes well, maybe the document is corruped and need some fixing (some big picture do this problem on printers) check with other documents if they print well.
If it goes wrong again, do all the same thing again but beffore reprint, download and install the last version of the driver for you printer/OS.
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printer paused
Hi
Go to control panel on your computer, then go to printers and other hardware or printers and faxes, right click on epson icon and left click on resume printing, or you can cancel the document then when it says 0 and ready as status, try printing again.
Hope this helps
Aug 25, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Pause/printer rest between pages
Hi nurse_boop (Lainey), You can try changing some of the printer settings. Assuming you're using Windows, go to Start, Printers and Faxes, and right click on your printer, choose Properties: 1. Make sure that you disable printer pooling; 2. Check/tick, print directly to the printer; 3. Check/tick, Printer is Always Available. Please keep in mind that large file sizes, images and deep colors adds to the slowdown and pauses of printers. Hardware wise, large documents requires more memory both on the printer server PC and the printer itself. Hope this be of some help to you. Post back how things are or should you need further information. Good luck and kind regards.
Aug 24, 2007 | Canon LBP 1120 Laser Printer
Lexmark E232 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
