Question about Samsung YP-Z5 MP3 Player
SAMSUNG YP-Z5 PLAYER NOT CHARGING!
I've had my player for over a year and worked fine until recently. The battery dies out really quickly and when i start charging the battery with the USB cable, the sign of the battery charging shows up and after about a minute the battery goes green (as if its fully charged) but when i go to turn the player on the battery sign goes red and says LOW BATTERY!
I've tried to ignore the sign and let it charge for 3-4hours and still does the same thing. I tried to reset it by the hidden button by where the USB cable is connected and nothing. AND also i have tried to format it (where it reboots the player and deletes everything) and still nothing. Oh lol and i've also tried charging it from different PC and Laptops and still says low battery! WHAT DO I DO?? :(
  • svhuerga Jan 24, 2009
    I have the same problem. And the device doesn´t also connect to the computer. I wonder if it's a problem of the cable. Do you know how can i try with a different cable?
U HAVE 2 RESET IT WIT A LEAD PENCIL IT AT THE BOTTAM IN THE BACK OF THE MP3 PLAYER™ IF THAT DONT WORK I DONT KNOW
Posted on Jan 28, 2009
I have the yp z5 model and it wont charge and the comp. wont recognize the device either. im guessing i should replace the battery because all of the components inside are still intact.
Try to take apart the player and disconnect the battery for a few minutes, then reconnect, reassemble and try charging it over the USB cable. It appears that some people have had some success after full disconnection of the battery from player. Alternatively, try eBay for a new battery - there are plenty there.
May 03, 2011 | Samsung YP-Z5 MP3 Player
Samsung 1gb yp-z5. wont charge, usb disabled. PS havent got any other usb ports to try, no keyboard additions.
Feb 20, 2011 | Samsung YP-Z5 MP3 Player
My Samsung YP-Z5 player wont respond to charging. Tried plugging into several USB ports on different computers but wont charge. Its constantly displaying .... Low Battery & USB Disabled. I was...
Yes, they only last two to three years.
A search of eBay, a place i look to check availability gives a number available.
Search "Samsung YP-Z5 battery"
If you are able to open up the case You could cut off the existing battery leads close to the battery and join the two wires. Soldering is preferred if you have an insulated tip soldering iron.
Otherwise twisting the wires together is probably good enough.
Tape the joins to strengthen and insulate them.
Feb 08, 2011 | Samsung YP-Z5 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
My YP-Z5 unresponsive
There is a reset button at bottom by the usb connection port, try pressing that i had similer problem downloaded the manual from samsung site which said try doing that so i did and now it seems to work fine
Nov 18, 2007 | Samsung YP-Z5 MP3 Player
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Oct 23, 2007 | Samsung YP-Z5 MP3 Player
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Jul 04, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Other way to sync the yp-z5 withought windows media player
Here is the user manual for your player if you need it; http://downloadcenter.samsung.com/content/UM/200601/20060124115711375_YPZ5-USA-ENGLISH-0.0.pdf Page 18 states that you can only sync with wmp 10, there is no alternative software that will do the job. Hope this helps :)
Apr 18, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
Samsung YP-Z5 MP3 Player Logo
346 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
