Question about Ovens
Cleaning glass on oven door
What is the best way to clean the glass on your oven door? I have a self-clean oven, but the glass always has brown marks on it. When my oven is cleaned, the glass on the interior of my new oven does not clean well, or really much at all. I called KitchenAid and they said to scrub with a little vinegar - it takes about 5 minutes per "mark", and that's not acceptable. I have never had this problem with other ovens. Better ideas anyone??
  • Ovens Master
  • 3,463 Answers
Get a stanley blade and scrape the glass clean that way, you will not hurt the glass, better if you can fit it in a holder of some sort.
I do mine that way, and it always gets the baked on fat and grease off.
Plz rate my solution.
Thanks.
Posted on Jan 07, 2009
  • arttighe Feb 09, 2013
    worked great ,what a time saver single dad
I have the same problem but it is also dirty between the glass panels which you can not get to. Love any thoughts. Thanks
Posted on Jan 04, 2010
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
I got brown marks on the top of the oven door when using the self cleaning mode. It is a white oven and now it looks bad due to the brown marks. Is there a way to get rid of these marks ?
The brown marks are caused by some food residue burning off during the clean cycle and is usually very hard to clean off. You might try using a Mr. Clean Magic eraser with some soft scrub. If that dose not do it you may have to replace stained parts.
Aug 28, 2011 | Ovens
We have a SMEG self cleaning oven however the glass door is filthy and we are seeking the best approach to clean it without damaging
Purchase 3M stainless cleaner for the stainless parts, do not use spray and wipe or similar as it removes the marking or etching indicators (temp. etc)
You can use oven cleaner on the glass, but try not to let it go on the stainless parts yet again.
Hope this helps?
Jun 21, 2009 | Smeg DO81CSS Electric Double Oven
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning better than self-cleaning
What you have read is correct, the catalytic lining can be damaged by corrosive sprays. It should be safe to use 'Easy Off ' on glass though.
The standard Auto clean cycle is the best method of cleaning that i know of.
Nov 29, 2008 | GE JTP86 Electric Double Oven
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Glass door on oven has water marks between glass
you have to remove the door and take it apart in order to clean the glass. that is the only way. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
422 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
