Question about Philips 9P5544C 55" Rear Projection Television
Phillips/Magnavox 9P5544C102 white raster and shuts down
55" Phillips-Magnavox rear screen. Chassis PTV840. When the TV is powerd on, you get a expanding white raster with horizontal lines and then the screen blacks out after a couple seconds. The power LED remains on (green). No on-screen menu or other controls.
    Genius:
  • 1,139 Answers
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
Posted on Sep 24, 2007
Picture on my magnavox 9p5544c102 is fuzzy with green tint
Its the CRT coolant which needs replacement. You can get the Phillips CRT coolant kit at www.tvrepairworld.com which contains the Coolant for all three CRT's plus has the CD with instructions.
Jul 14, 2010 | Philips 9P5544C 55" Rear Projection...
Where can we find a replacement bulb for 9p5544c102
Your TV uses tubes - red - green - blue - tubes.
What is the issue? These tubes are fairly hardy in the Magnavox TV sets.
Dec 11, 2009 | Philips 9P5544C 55" Rear Projection...
Phillips/Mag Projection TV-9P5544C102 no pic/sound /pwr light on
John, my thoughts is something in the main power supply. I don't know what an opto chip is but I've heard of Optocupler IC's.
May be a good idea to give a call to some local TV Repair Shops especially ones that work on Philip's and see if you can speak with a tech to see what their thoughts are on what the problem is and what a repair cost may be.
The issue is one of hauling it to the TV shop or having them come out to you.
Blessings,
A/V Media Guy
Nov 20, 2009 | Televison & Video
55'' philips rear projection turns on no video/audio. 9p5544c102
Try removing the two convergence chips from the board - then see if the TV powers on and lights up. If so you narrowed it down. If not - you have eliminated convergence IC problems.
Nov 04, 2009 | Televison & Video
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips PTV840 55" rear projection TV
You canget a Factory Service manual from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Apr 28, 2008 | Philips 9P5544C 55" Rear Projection...
Picture issue with Philips 64" Big Screen
don't know if this is same problem or not but try this:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.keohi.com/keohihdtv/brandspecific/philips/philips_convergence_geometry.html
Dec 05, 2007 | Philips Magnavox 9P6034C 60" Rear...
POWERS DOWN AFTER 4 SEC
crt beam current too high causing shutdown as you know. Check cathode voltage of each cathode, normal levels depend on picture is around 130-150V. Missing 200V to crt board. Screen voltage problem normal 300-500V. Flyback or bad crt. ABL circuit problem. Jungle IC.
Oct 29, 2007 | Philips Magnavox TP3285C 32" TV
Philips 9P5544C 55" Rear Projection Television Logo
475 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
