Question about GE WSXH208A Front Load Washer
I have seen a reference to a solution posted by john_in_erie on how to install a new gasket on ge front loading washing machine WSXH208A but i am unable to find this particular post - could someone please help me locate the post. thanks.
I've been looking too. And finally found it! john_in_erie
Rank:i have seen a reference - nonexpert_s.gif Apprentice
Rating: 98%, 12 votes Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Posted on Jan 26, 2009
Got a decimal point in the minutes and is not starting and is counting in sec not mins front loading washer ge adora 4-5 yrs old
What is the model number that is posted on the machine? On the model number that is posted above I do not see in the database that it has a LED display readout.
Feb 08, 2011 | GE WSXH208A Front Load Washer
Front load GE wcvh6260hww gasket is ripped Where do i get a new one and how do i replace?
I have not replaced a gasket myself (had warranty service) but when it was complete, I made sure to tilt the washer slightly backwards so the clothes did not get into the gasket so easily. After two replacements in the first three months, we have not had to replace for more than two years. Hope this helps when you get the new one in.
Oct 16, 2010 | GE WSXH208A Front Load Washer
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
Drum came out of rubber skirt around door
Check that it is not ripped
Take the power off
Take the top off
Refit the gasket witha new clip
Dec 06, 2009 | GE WSXH208A Front Load Washer
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
I have a GE front loader that leaks from the bottom, any ideas what it is from?
Is it coming from the front? You can take the bottom panel off and look inside. If the middle is not wet, it may be from a torn door gasket. Pull back the rubber seal on the machine (not the door) and you may see a big tear. That's what happened to ours. We ordered a new one on ebay and we are installing it now.
Apr 11, 2009 | GE WSXH208A Front Load Washer
Front load GE washer
you just push the delay button once and the light will go off.
Oct 17, 2008 | GE WSXH208A Front Load Washer
Torn gasket on a front load ge washer
Not too hard or technical. I followed John in Erie's instructions:
I bought my part at Appliance Zone. From what I paid and how long it took to get to me, I should have just bought it locally for a little more and had it delivered a lot sooner. Replacement took an hour and a half.
Apr 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Elite front load
not much to go on,the gasket would not stop it agiating, but it should stop it leaking if it was the problem in first place
Oct 29, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
97 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
